How to Install and Remove Expansion Cards
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
66
All Time:
669
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 seconds - 1 minute
Difficulty: Very easy
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
This guide shows how to install and remove Expansion Cards for your Framework Laptop.
All official Expansion Cards work fully in all slots, so you can install them however you wish!
The Expansion Cards are hot-swappable. You can install and remove them without turning off your laptop.
    1. How to Install and Remove Expansion Cards, Set your laptop down: step 1, image 1 of 1
      • Set your laptop face-down on a clean work surface.
      Ask FixBot
    2. How to Install and Remove Expansion Cards, Install an Expansion Card: step 2, image 1 of 3 How to Install and Remove Expansion Cards, Install an Expansion Card: step 2, image 2 of 3 How to Install and Remove Expansion Cards, Install an Expansion Card: step 2, image 3 of 3
      • The next two steps show how to install an Expansion Card.
      • Slide an Expansion Card into an Expansion Card slot.
      • You don't need to unlock the latches to install the Expansion Cards—only when you want to remove them.
      • The Expansion Cards should click into place, and the front edge should be flush with the laptop.
      Ask FixBot
    3. How to Install and Remove Expansion Cards: step 3, image 1 of 2 How to Install and Remove Expansion Cards: step 3, image 2 of 2
      • If there's a red bar showing under the Expansion Card latch, use your finger to flip the latch and lock the Expansion Card into its slot.
      • Locking the Expansion Card slots helps keep the cards in place when you unplug cables from them.
      Ask FixBot
    4. How to Install and Remove Expansion Cards, Remove an Expansion Card: step 4, image 1 of 2 How to Install and Remove Expansion Cards, Remove an Expansion Card: step 4, image 2 of 2
      • The next two steps show how to remove an Expansion Card.
      • Use your fingers to flip the two Expansion Card latches (one for each side) into the unlocked position.
      • The latches display a red bar when they're unlocked.
      Ask FixBot
    5. How to Install and Remove Expansion Cards: step 5, image 1 of 3 How to Install and Remove Expansion Cards: step 5, image 2 of 3 How to Install and Remove Expansion Cards: step 5, image 3 of 3
      • Grip the lip of the Expansion Card with your fingers.
      • Pull the Expansion Card out of its slot and remove it.
      • If you have trouble pulling the Expansion Card out, you can also use the flat end of your Framework Screwdriver to push against the lip.
      Ask FixBot
If you need help, contact Framework support.
Arthur Shi
351,901 Reputation
937 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,154 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 66
All Time: 669
