Up to 20% off select tools
How to Install an HID Conversion Kit
Views: 23K
View statistics:
Past 24 Hours:
9
Past 7 Days:
72
Past 30 Days:
343
All Time:
22,640
Comments: 1
1 guide comment.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 18
18 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
If you're tired of your halogen headlights or fog lights and want to upgrade to something with a better output, try installing an HID Conversion Kit.
    1. How to Install an HID Conversion Kit, Headlights: step 1, image 1 of 2 How to Install an HID Conversion Kit, Headlights: step 1, image 2 of 2
      • Open the hood.
      • Locate the back of the headlights and remove the bolts holding the headlight housing.
      Ask FixBot
    2. How to Install an HID Conversion Kit: step 2, image 1 of 1
      • Unplug the stock harness and remove the headlights.
      Ask FixBot
    3. How to Install an HID Conversion Kit: step 3, image 1 of 2 How to Install an HID Conversion Kit: step 3, image 2 of 2
      • Remove battery negative terminal.
      • Remove headlight cover and remove factory halogen bulb.
      Ask FixBot
    4. How to Install an HID Conversion Kit: step 4, image 1 of 1
      • Take out the HID bulb from the plastic shell and remove the circular plastic piece.
      • Remember not to touch the HID bulb glass!
      • If you accidentally touch it, you can clean it with some rubbing alcohol.
      Ask FixBot
    5. How to Install an HID Conversion Kit: step 5, image 1 of 2 How to Install an HID Conversion Kit: step 5, image 2 of 2
      • Screw in the HID bulb back into the headlight housing.
      • Connect the wires of the HID bulb to the ballast and then connect the HID ballast back to the stock harness.
      Ask FixBot
    6. How to Install an HID Conversion Kit: step 6, image 1 of 1
      • Before you mount the ballast, test the HID light to make sure it lights up.
      • If not, turn the adapter wire 180 degrees.
      • Mount the HID ballast with zip ties.
      Ask FixBot
    7. How to Install an HID Conversion Kit: step 7, image 1 of 3 How to Install an HID Conversion Kit: step 7, image 2 of 3 How to Install an HID Conversion Kit: step 7, image 3 of 3
      • Put everything (like the headlight housing) back.
      • Enjoy!
      Ask FixBot
Enjoy your new HID Conversion Kit and upgraded headlights or fog lights.
7 other people completed this guide.
Author
with
Eric Wu
3,600 Reputation
23 Guides authored
1 Guide Comment
Tradução em português sff.
Dall Costa - Reply Share
Past 24 Hours: 9
Past 7 Days: 72
Past 30 Days: 343
All Time: 22,640
