How to Install a Plastic Snap With a Handheld Tool
    1. How to Install a Plastic Snap With a Handheld Tool, Snap information: step 1, image 1 of 2 How to Install a Plastic Snap With a Handheld Tool, Snap information: step 1, image 2 of 2
      • A full set of plastic snaps consists of four parts:
      • Two caps
      • One stud
      • One socket
      • When the snap is installed, the socket and stud will lock together, while a cap holds each of them in place from the other side of the fabric.
      Ask FixBot
    2. How to Install a Plastic Snap With a Handheld Tool, Pierce the fabric: step 2, image 1 of 2 How to Install a Plastic Snap With a Handheld Tool, Pierce the fabric: step 2, image 2 of 2
      • Push the point of an awl through the fabric to pierce a hole for the snap.
      • It's better to measure twice, pierce once! Piercing the fabric multiple times within a small area will weaken the fabric.
      Ask FixBot
    3. How to Install a Plastic Snap With a Handheld Tool, Install the snap: step 3, image 1 of 3 How to Install a Plastic Snap With a Handheld Tool, Install the snap: step 3, image 2 of 3 How to Install a Plastic Snap With a Handheld Tool, Install the snap: step 3, image 3 of 3
      • Use your fingers to squeeze a cap pin through the fabric hole.
      Ask FixBot
    4. How to Install a Plastic Snap With a Handheld Tool: step 4, image 1 of 3 How to Install a Plastic Snap With a Handheld Tool: step 4, image 2 of 3 How to Install a Plastic Snap With a Handheld Tool: step 4, image 3 of 3
      • Place either a stud or a socket on top of the pin.
      • If you can't see the pin after placing the stud or socket, the fabric is too thick for the snap. You'll need a cap with a longer pin.
      Ask FixBot
    5. How to Install a Plastic Snap With a Handheld Tool: step 5, image 1 of 2 How to Install a Plastic Snap With a Handheld Tool: step 5, image 2 of 2
      • Make sure the snap is facing the correct side for the clothing item.
      • Center the snap components in the fastener tool. The cap should sit fully in the black die cup.
      Ask FixBot
    6. How to Install a Plastic Snap With a Handheld Tool: step 6, image 1 of 3 How to Install a Plastic Snap With a Handheld Tool: step 6, image 2 of 3 How to Install a Plastic Snap With a Handheld Tool: step 6, image 3 of 3
      • Firmly squeeze the fastener tool handles. The white rubber head should bulge slightly from the force.
      • Release the handles and remove the tool from the snap.
      Ask FixBot
    7. How to Install a Plastic Snap With a Handheld Tool, Check the new snap: step 7, image 1 of 2 How to Install a Plastic Snap With a Handheld Tool, Check the new snap: step 7, image 2 of 2
      • Visually inspect the snap. The center pin should be evenly flattened.
      • Pull on the snap. The snap shouldn't feel loose.
      • If the pin isn't evenly flattened or the snap feels loose, use the fastener tool to compress the snap again. If that doesn't fix it, remove the snap and start again.
      Ask FixBot
    8. How to Install a Plastic Snap With a Handheld Tool, Install the other half of the set: step 8, image 1 of 3 How to Install a Plastic Snap With a Handheld Tool, Install the other half of the set: step 8, image 2 of 3 How to Install a Plastic Snap With a Handheld Tool, Install the other half of the set: step 8, image 3 of 3
      • Repeat the procedure to install the other half of the snap set.
      Ask FixBot
For more clothing repair guides, click here.
2 other people completed this guide.
Arthur Shi
347,826 Reputation
927 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 64
Past 30 Days: 301
All Time: 4,579
