How to Install a Fifth String Shubb Banjo Capo
Views: 8.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
149
All Time:
8,924
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use basic skills and handy work to install a capo that will expand the library of tablature available to your musical abilities. A fifth string capo is intended to adjust the tuning of the fifth (G) string on the banjo without having to constantly adjust the fifth string tuning key.
This installation process can be pretty intimidating, but if you approach it cautiously and double check your measurements, this fix can be empowering and rewarding.
    1. How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: step 1, image 1 of 3 How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: step 1, image 2 of 3 How to Install a Fifth String Shubb Banjo Capo, How to Install a Fifth String Shubb Banjo Capo: step 1, image 3 of 3
      • Line the capo up along the fifth string side of the fretboard as shown.
      • Line the capo screw holes up about 12 mm from the fifth fret bar and about 4 mm from the face of the fret.
      • Be careful not to line the capo screw holes up directly below a fret bar or directly on top of a fret marker.
      Ask FixBot
    2. How to Install a Fifth String Shubb Banjo Capo: step 2, image 1 of 1
      • Use the marker to mark where the screws should go.
      Ask FixBot
    3. How to Install a Fifth String Shubb Banjo Capo: step 3, image 1 of 1
      • Use the drill to drill both holes for the two screws.
      • The holes should be drilled about 1 cm deep
      • You may need to borrow an extra pair of hands to help you stabilize the banjo while you perform this step.
      Ask FixBot
    4. How to Install a Fifth String Shubb Banjo Capo: step 4, image 1 of 2 How to Install a Fifth String Shubb Banjo Capo: step 4, image 2 of 2
      • Use the flat head screw driver to insert and tighten the screws.
      Ask FixBot
    5. How to Install a Fifth String Shubb Banjo Capo: step 5, image 1 of 3 How to Install a Fifth String Shubb Banjo Capo: step 5, image 2 of 3 How to Install a Fifth String Shubb Banjo Capo: step 5, image 3 of 3
      • To use the capo, slide the capo finger down to the desired fret.
      • Then, tighten the spring knob.
      Ask FixBot
For more information check out the Shubb fifth string capo website at: http://www.shubb.com/fs/index.html
6 other people completed this guide.
Sara Wier
263 Reputation
1 Guide authored
Cal Poly, Team 23-4, Green Winter 2015 Member of Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
7 Members
72 Guides authored
1 Guide Comment
thank you. Now, I know how to do and i décide to buy a shubb and to install it
Jean-Denis Del - Reply Share
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 149
All Time: 8,924
