How to Install a 2.5" SSD Into a Silicone Enclosure
    1. How to Install a 2.5" SSD Into a Silicone Enclosure, Insert the SSD into the enclosure: step 1, image 1 of 2 How to Install a 2.5" SSD Into a Silicone Enclosure, Insert the SSD into the enclosure: step 1, image 2 of 2
      • Before you insert the new hard drive, note the orientation of the SATA connectors embedded in the enclosure:
      • The wide power SATA port
      • The narrower data SATA port
      Ask FixBot
    2. How to Install a 2.5" SSD Into a Silicone Enclosure: step 2, image 1 of 3 How to Install a 2.5" SSD Into a Silicone Enclosure: step 2, image 2 of 3 How to Install a 2.5" SSD Into a Silicone Enclosure: step 2, image 3 of 3
      • Using the previous step, orient the new drive so that its SATA connectors will align with the enclosure's.
      • Slide the drive into the enclosure's opening.
      • Push the drive into the enclosure until it stops sliding and the SATA connectors are completely seated.
      Ask FixBot
    3. How to Install a 2.5" SSD Into a Silicone Enclosure: step 3, image 1 of 3 How to Install a 2.5" SSD Into a Silicone Enclosure: step 3, image 2 of 3 How to Install a 2.5" SSD Into a Silicone Enclosure: step 3, image 3 of 3
      • Stretch the remaining enclosure corners over the drive so that the silicone cover encapsulates the drive.
      Ask FixBot
Your drive is ready to be used!
3 other people completed this guide.
Arthur Shi
350,914 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 24
Past 30 Days: 105
All Time: 2,794
