Up to 20% off select tools
How to Install LED License Plate Lights
Views: 19K
View statistics:
Past 24 Hours:
8
Past 7 Days:
68
Past 30 Days:
290
All Time:
18,584
Comments: 2
2 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
If you wanted to change out your license plate lights, installing new LED license plate lamps is actually quite a piece of cake. You will have a new look with minimal effort in no time. This installation will not take much time and is great for beginners.
    1. How to Install LED License Plate Lights, Prep work: step 1, image 1 of 1
      • You can choose to raise your car with a car lift jack to get better access to the license plate area. This is not absolutely necessary, but will make installation easier.
      Ask FixBot
    2. How to Install LED License Plate Lights, Removing the stock bulb: step 2, image 1 of 3 How to Install LED License Plate Lights, Removing the stock bulb: step 2, image 2 of 3 How to Install LED License Plate Lights, Removing the stock bulb: step 2, image 3 of 3
      • Pull out the license plate lamp assembly and remove the stock license plate bulb.
      Ask FixBot
    3. How to Install LED License Plate Lights, Installing the LED license plate bulb: step 3, image 1 of 2 How to Install LED License Plate Lights, Installing the LED license plate bulb: step 3, image 2 of 2
      • Install back the new LED license plate bulb.
      • Test to make sure the LED bulb works.
      Ask FixBot
    4. How to Install LED License Plate Lights, Putting the license plate assembly back: step 4, image 1 of 2 How to Install LED License Plate Lights, Putting the license plate assembly back: step 4, image 2 of 2
      • Put the license plate assembly back and repeat on the other side.
      Ask FixBot
    5. How to Install LED License Plate Lights, Enjoy: step 5, image 1 of 1
      • Once everything works, you can enjoy your new LED license plate look.
      Ask FixBot
See how easy installing these LED license plate lights are? It's almost unbelievable how a quick and simple installation could make such a difference.
6 other people completed this guide.
Author
with
Eric Wu
3,600 Reputation
23 Guides authored
2 Guide Comments
Why do all your pics have such obnoxious watermarks? If the pics are specifically for iFixit.com I would remove the watermarks.
David Spalding - Reply Share
Good information!
limoh - Reply Share
Past 24 Hours: 8
Past 7 Days: 68
Past 30 Days: 290
All Time: 18,584
