Up to 20% off select tools
How to Install ChromeOS Flex
View statistics:
Past 24 Hours:
12
Past 7 Days:
55
Past 30 Days:
304
All Time:
602
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace Microsoft Windows or Apple MacOS with ChromeOS Flex on a desktop or laptop computer.
ChromeOS Flex is an operating system developed and maintained by Google. If you only use Google Chrome on your computer, installing ChromeOS Flex is a great way to extend its usable life.
Check if your device is in the ChromeOS Flex Certified models list. If it isn't certified, you may run into issues.
Back up all important data before beginning this guide.
    1. How to Install ChromeOS Flex, Prepare for installation: step 1, image 1 of 2 How to Install ChromeOS Flex, Prepare for installation: step 1, image 2 of 2
      • Installing ChromeOS Flex will erase the data and operating system on your computer. Disconnect any storage devices you don't want erased.
      • Create a full system backup using our Clonezilla backup guide, or copy your important files to separate drive. Disconnect the backup drive before continuing.
      • If you're using a laptop, connect its power adapter so it's charging.
      Ask FixBot
    2. How to Install ChromeOS Flex, Connect the USB drive: step 2, image 1 of 3 How to Install ChromeOS Flex, Connect the USB drive: step 2, image 2 of 3 How to Install ChromeOS Flex, Connect the USB drive: step 2, image 3 of 3
      • If you purchased a ChromeOS Flex USB drive, it's ready to go. If you're using a different flash drive, follow this guide to put ChromeOS Flex on it.
      • Connect the USB flash drive to the fastest available port on the computer.
      • Use a USB 3 drive connected to a USB 3 port for faster installation. USB 3 ports are usually colored blue and/or labeled SuperSpeed (SS).
      Ask FixBot
    3. How to Install ChromeOS Flex, Boot from USB drive (Windows): step 3, image 1 of 3 How to Install ChromeOS Flex, Boot from USB drive (Windows): step 3, image 2 of 3 How to Install ChromeOS Flex, Boot from USB drive (Windows): step 3, image 3 of 3
      • If you're using a Mac, skip this step.
      • If you're using Windows 7:
      • Restart the computer and repeatedly press the boot key specific to your device (like F2, F12, etc.). Click here for a table of boot keys for common brands.
      • Use the arrow keys to highlight the USB drive (beginning in UEFI:) from the list of options, then press Enter to boot from it. Skip the remainder of this step.
      • Open the Settings app and navigate to Update & Security → Recovery then select "Restart now" under Advanced startup.
      • You can also hold the Shift key while clicking Restart in the Start Menu.
      • In Advanced startup navigate to Use a device → UEFI: USB. This will boot the computer from the USB drive.
      • If the USB option doesn't appear in this menu, select Continue to restart the computer and try again.
      Ask FixBot
    4. How to Install ChromeOS Flex, Boot from the USB drive (Mac): step 4, image 1 of 3 How to Install ChromeOS Flex, Boot from the USB drive (Mac): step 4, image 2 of 3 How to Install ChromeOS Flex, Boot from the USB drive (Mac): step 4, image 3 of 3
      • If you're using a Windows PC, skip this step.
      • Shut down the Mac.
      • Press the power button and immediately hold down the Option key. Wait for the boot options to pop up.
      • Select the EFI Boot option to boot from the USB drive.
      Ask FixBot
    5. How to Install ChromeOS Flex, Try ChromeOS Flex: step 5, image 1 of 3 How to Install ChromeOS Flex, Try ChromeOS Flex: step 5, image 2 of 3 How to Install ChromeOS Flex, Try ChromeOS Flex: step 5, image 3 of 3
      • The ChromeOS Flex installer allows you to try the operating system from the USB drive before installing it on your hardware. If you'd prefer to install it right away, skip the next two steps.
      • Click Get started, then Try it first.
      • Select Browse as Guest in the bottom‑left corner.
      • You can also sign in to your Google account, if you'd like.
      • If you've changed your mind about trying it first, select Install ChromeOS Flex and skip the next step.
      Ask FixBot
    6. How to Install ChromeOS Flex: step 6, image 1 of 2 How to Install ChromeOS Flex: step 6, image 2 of 2
      • Test all the features of your computer, like the keyboard, mouse, touchpad, webcam, Wi‑Fi, and touchscreen.
      • Browse the web and navigate the operating system to ensure it's what you expect.
      • Once you're ready, click the time in the bottom‑right corner and select Exit guest (or Sign out if you've signed in with a Google account). This will take you back to the installer.
      Ask FixBot
    7. How to Install ChromeOS Flex, Install ChromeOS Flex: step 7, image 1 of 3 How to Install ChromeOS Flex, Install ChromeOS Flex: step 7, image 2 of 3 How to Install ChromeOS Flex, Install ChromeOS Flex: step 7, image 3 of 3
      • Ensure the Install ChromeOS Flex option is selected, then click Next.
      • Review the warning explaining that the installer will permanently erase the data on the computer.
      • Click Install ChromeOS Flex when you're ready to install. Then, click Install on the pop‑up window.
      Ask FixBot
    8. How to Install ChromeOS Flex: step 8, image 1 of 3 How to Install ChromeOS Flex: step 8, image 2 of 3 How to Install ChromeOS Flex: step 8, image 3 of 3
      • Wait for the installer to complete. When it does, it'll shut down the computer automatically.
      • Once it's shut down, unplug the USB drive.
      • Power on the computer to begin using ChromeOS Flex.
      Ask FixBot
    9. How to Install ChromeOS Flex, Sign in to ChromeOS Flex: step 9, image 1 of 3 How to Install ChromeOS Flex, Sign in to ChromeOS Flex: step 9, image 2 of 3 How to Install ChromeOS Flex, Sign in to ChromeOS Flex: step 9, image 3 of 3
      • Connect to the internet and accept the Terms of Service, if prompted.
      • Select the type of Google account you'd like to sign in to, then click Next.
      • Wait for ChromeOS Flex to update. The progress is indicated on the left.
      • If you'd like to skip updating for now, click Skip and remind me later in the bottom‑right corner.
      • Click Next and follow the prompts to sign in to ChromeOS Flex.
      Ask FixBot
    10. How to Install ChromeOS Flex, Update ChromeOS Flex: step 10, image 1 of 3 How to Install ChromeOS Flex, Update ChromeOS Flex: step 10, image 2 of 3 How to Install ChromeOS Flex, Update ChromeOS Flex: step 10, image 3 of 3
      • If your system was updated in the previous step, skip this one.
      • Click the time in the bottom‑right corner of the screen.
      • Click the gear icon to open the Settings window.
      • Click About ChromeOS on the sidebar, then Check for Updates to get the system up‑to‑date. Restart the system if prompted.
      Ask FixBot
    11. How to Install ChromeOS Flex, Erase the USB drive (optional): step 11, image 1 of 3 How to Install ChromeOS Flex, Erase the USB drive (optional): step 11, image 2 of 3 How to Install ChromeOS Flex, Erase the USB drive (optional): step 11, image 3 of 3
      • If you want to keep the ChromeOS Flex installer on the USB drive, skip this step.
      • Connect the USB drive to the computer.
      • Add the Chromebook Recovery Utility extension to your browser.
      • Open the extension and click the gear icon in the top‑right corner. Click Erase recovery media.
      • Select the USB drive you want erased from the drop‑down menu, then click Continue.
      • Verify the USB drive listed is the one you want erased, then click Erase now. Wait for the process to complete, and you're done!
      Ask FixBot
Congratulations! You've successfully installed ChromeOS Flex.
Didn't go as planned? Try asking our ChromeOS Answers Community for help.
Nick Schultz
71,265 Reputation
363 Guides authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 55
Past 30 Days: 304
All Time: 602
