How to Hem Sweatpants
Views: 17K
View statistics:
Past 24 Hours:
28
Past 7 Days:
221
Past 30 Days:
855
All Time:
17,104
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Easy
Introduction
Go to step 1 ↓
This detailed 9 step guide will teach you how to hem sweatpants with elastic at the leg opening. This guide is easy to follow and anyone can do it.
The process requires a very basic knowledge of sewing, and can be done either with a sewing needle or a sewing machine, with the steps displaying how to use either. You also need to know how to use a seam ripper.
Lastly, like most guides hemming a pant leg, this process is not reversible, so make sure you measure correctly.
Tools
    1. How to Hem Sweatpants, How to Hem Sweatpants: step 1, image 1 of 2 How to Hem Sweatpants, How to Hem Sweatpants: step 1, image 2 of 2
      • Use the seam ripper to remove the seams along the hem of the bottom of the pants.
      Ask FixBot
    2. How to Hem Sweatpants: step 2, image 1 of 1
      • Remove the elastic band from the pants. Keep the elastic for later.
      Ask FixBot
    3. How to Hem Sweatpants: step 3, image 1 of 1
      • Place pins where you want the pants to end.
      Ask FixBot
    4. How to Hem Sweatpants: step 4, image 1 of 3 How to Hem Sweatpants: step 4, image 2 of 3 How to Hem Sweatpants: step 4, image 3 of 3
      • Measure the length of the cuff.
      • Measure how long the pants need to be cut.
      • Keeping in mind a small length below the pins for the new cuff, mark where you want to cut with your washable marker.
      Ask FixBot
    5. How to Hem Sweatpants: step 5, image 1 of 1
      • Using the fabric scissors, cut along the line you marked, making sure to keep a straight and steady line.
      Ask FixBot
    6. How to Hem Sweatpants: step 6, image 1 of 1
      • Fold the new end of the pants outward, at a minimum of double the length of the elastic band.
      Ask FixBot
    7. How to Hem Sweatpants: step 7, image 1 of 2 How to Hem Sweatpants: step 7, image 2 of 2
      • Place the elastic band on top of the fold from the previous step.
      • Place the top of the elastic along the pin line.
      • Using the needle and thread, sew both ends of the elastic band to the seam running vertically up and down the pant leg.
      Ask FixBot
    8. How to Hem Sweatpants: step 8, image 1 of 2 How to Hem Sweatpants: step 8, image 2 of 2
      • Fold the top of the folded fabric section back over the elastic, using the pins as the top line.
      • Place pins along the bottom of the new fold to keep the fabric in place.
      Ask FixBot
    9. How to Hem Sweatpants: step 9, image 1 of 3 How to Hem Sweatpants: step 9, image 2 of 3 How to Hem Sweatpants: step 9, image 3 of 3
      • Sew a new hem along the line created by the new pins. You can either hand-sew or use a sewing machine.
      • Sew ONLY along the new pins placed in the previous step. Do not sew along the first row of pins created at the beginning.
      • Once the sewing is complete, remove all the pins and undo the first fold.
      • The last photo provides a sample of the finished product.
      Ask FixBot
Finish Line
1 Guide Comment
Thanks very much for this tutorial because at 5’ I have to shorten everything. Now I can alter sweatpants that are made for 6’ tall people.
Ruthann45 - Reply Share
Past 24 Hours: 28
Past 7 Days: 221
Past 30 Days: 855
All Time: 17,104
