Introduction
Use this guide to clear common Siemens dishwasher E23 draining problems caused by a blocked filter, spray propeller, waste water pump impeller, drainage hose, or drainage U-bend. The waste water pump impeller, also called the fan impeller or pump propeller, must spin freely so the dishwasher can drain properly. Clean these areas when the dishwasher won't drain well, shows E23, or leaves dishes dirty. These instructions were written for a Siemens Bosch-style dishwasher with two spray propellers; other Bosch/Siemens models may have minor differences.
Step 2 Remove baskets and clean the upper spray propeller
Pull the upper basket partway out to access the upper spray propeller.
Turn the upper spray propeller counterclockwise and pull it off.
Rinse the propeller under the tap and make sure water flows freely from the spray holes.
Push the propeller back onto its mount, turn it clockwise until it clips in, and check that it spins freely.
Squeeze both upper basket handles inward and pull the basket out.
Roll the lower basket forward and lift it out.
Step 3 Remove and clean the filter and lower spray propeller
Turn the filter counterclockwise and lift it out of the bottom of the dishwasher.
Check the filter for residue, food bits, and debris.
Rinse the filter under the tap and use an brush to loosen stuck-on grime.
Lift the lower spray propeller straight up and out of the tub.
Rinse the lower spray propeller under the tap and make sure water comes out of the spray holes.
Set the clean filter and lower spray propeller aside while you clean the pump area.
Step 4 Remove water from the pump well
Press an old sponge into the pump well to soak up excess water.
Wring the sponge into a sink or bucket.
Repeat two or three times until the pump well is as dry as you can get it.
Step 5 Clean the waste water pump impeller
Push the white pump cover clip inward until it clicks free, and lift the cover out.
Check the cover for debris and wash it under the tap.
Use tweezers to pull visible hair, food bits, and residue from the waterway.
Use an brush to brush out remaining goo around the pump opening.
Turn the pump impeller blade with a finger and confirm that it rotates freely.
Step 6 Reinstall the pump cover and filter
Refit the pump protective cover and align the small groove at the rear.
Press the cover down until it clicks into place.
Use the end of a metal spoon to press the cover if your fingers can't seat it fully.
Reinstall the lower spray propeller.
Reinstall the clean filter and turn it clockwise until it clicks.
Step 7 Inspect the rear drain hose
Keep the dishwasher unplugged and pull it out far enough to reach the rear drain hose.
Place a bucket and old sponge at the rear because water will spill from the drain hose.
Disconnect the drain hose from the drainage pipe and empty the hose into the bucket.
Look down the hose end and remove any obvious blockage or residue.
Step 8 Check the drainage U-bend
Place a plastic tray under the drainage U-bend to catch water.
Hand-loosen the plastic U-bend connector or connectors.
Release the top clip or screws if the pipe is attached to the wall.
Remove the U-bend pipe and pour any excess water into the sink.
Inspect the inside of the U-bend for residue, buildup, and blockages.
Clean out any blockage you find.
Step 9 Reconnect the drain parts
Fit the U-bend pipe back into position.
Hand-tighten the plastic connector or connectors only.
Reconnect the waste pump hose securely.
Check that the drain hose route isn't kinked.
Firmly nudge the dishwasher side to side and up and down if you suspect the level sensor is stuck.
Step 10 Reassemble and test the dishwasher
Slide the upper basket back onto its rails until the handles lock.
Put the lower basket back into the dishwasher.
Plug the dishwasher in and press Start to test it.
If E23 returns or draining is still poor, unplug the dishwasher and inspect the remaining drainage hoses for blockages.
Have a dishwasher technician inspect the waste water pump motor if the issue remains.
Clean the filter, spray propellers, pump impeller area, drain hose, and drainage U-bend regularly to help the dishwasher drain well and wash efficiently. Repair didn't go as planned? Ask our Answers community for help.
