How to Fix the Samsung Dishwasher LC Error Code
Video Guide
This guide was transcribed from a YouTube video.
      • Switch off the dishwasher circuit breaker before opening panels or moving the dishwasher.
      • Most Samsung dishwashers are hardwired and don't have an on/off switch on the appliance.
      • Turn off the dishwasher water supply if you need to move the dishwasher far enough to strain a water line.
      • The LC code means the dishwasher has detected moisture or a leak near the water lines, drain, or bottom pan.
      • WARNING: Water and household wiring can shock you. Don't touch any wires until the breaker is off and you've verified the power is off.
      Ask FixBot
      • Open the sink cabinet and locate the dishwasher drain line.
      • Check the cabinet floor under the sink for water.
      • Make sure the dishwasher drain connection is dry.
      • Clear any clog or old food from the drain line before taking the dishwasher apart.
      • A clogged drain can hold dirty water in the system and trip the LC error.
      Ask FixBot
      • Use a screwdriver to remove the two screws from the lower access plate at the bottom front of the dishwasher.
      • Pull the lower access plate off the dishwasher.
      • Look under the front of the dishwasher for water.
      • Locate the electrical junction box area where the wires enter the dishwasher.
      • WARNING: Keep your hands out of the junction box unless the breaker is off and the wires are verified de-energized.
      Ask FixBot
      • Check whether the electrical cable has enough slack for the dishwasher to slide out.
      • If the cable is too tight, use a screwdriver to remove the junction box cover screw.
      • WARNING: Use a non-contact voltage tester to confirm the wires are de-energized before touching them.
      • Disconnect the three wires inside the junction box and pull the cable free.
      • Mark or photograph the wire connections so they go back in the same positions during reassembly.
      • WARNING: Stop and call a qualified technician if you're not comfortable working with house wiring.
      Ask FixBot
      • Open the dishwasher door and check how the dishwasher is mounted to the cabinet opening.
      • Look for two top mounting clips under the countertop, or side clips screwed into the cabinets or trim.
      • Use a screwdriver to remove the two top screws or the two side screws for your installation.
      • Press the blue tabs on both sides and slide the tray out if it blocks access to the side screws.
      • Keep the screws and clips in a safe spot so they don't get lost.
      Ask FixBot
      • Pull the dishwasher straight out from the cabinet opening.
      • Lift the dishwasher a few centimeters while pulling if a tile or hardwood floor lip catches the front of the unit.
      • Move slowly so the water line, drain line, and electrical cable don't stretch or kink.
      • Use a towel under the feet to avoid scratching the floor.
      • A properly finished floor under the dishwasher lets the unit slide out more easily.
      Ask FixBot
      • Slide the racks or trays out of the dishwasher.
      • Turn the filter from the locked position to the unlocked position and lift it out.
      • Wash the filter until it's free of food and debris.
      • Lift out the screen and wash it as well.
      • Check the drain cavity for an obvious clog.
      • Use a wet/dry vacuum to remove residual water from the drain area.
      • Some water may remain in the drain area even when the dishwasher is working normally.
      Ask FixBot
      • Wear work gloves before handling the underside of the dishwasher.
      • Carefully tip the dishwasher onto its side so you can access the bottom pan.
      • Inspect the underside and the bottom pan for water.
      • The bottom pan holds leak water so it doesn't immediately flood the kitchen.
      • Don't ignore water in the pan, because an active leak can damage hardwood floors or leak into the space below.
      Ask FixBot
      • Use a Phillips screwdriver to remove the screw holding the bottom pan.
      • Store the screw in a safe place.
      • Use a flathead screwdriver to gently pry the small clips holding the bottom pan.
      • Remove the bottom pan from the bottom of the dishwasher.
      • Samsung DW80 and similar models may use one screw and several clips, but other models may differ.
      Ask FixBot
      • Locate the white leak sensor in the bottom pan.
      • Use a microfiber cloth or paper towel to wipe up all water in the pan.
      • Wipe the metal sensor nodes until they are dry.
      • The sensor nodes detect water and put the dishwasher into the LC fault state.
      • Don't relocate or defeat the leak sensor to hide a recurring LC error, because it protects the floor from real leaks.
      Ask FixBot
      • Feel around the main drain at the bottom of the dishwasher for moisture.
      • Follow the drain line toward the exit and check for wet spots.
      • Follow the water intake line by hand and check for wet spots.
      • Check the motor area for moisture.
      • Release the butterfly clip on the main drain only if you need to check inside for old food or a clog.
      • Clear any debris you find, and reinstall the butterfly clip before closing the dishwasher.
      Ask FixBot
      • Align the bottom pan in its original position.
      • Push the pan into the clips until it sits securely.
      • Use a screwdriver to reinstall the bottom pan screw.
      • Use a drill at low speed only if you can avoid stripping the screw or plastic.
      • Carefully stand the dishwasher upright.
      • Slide the dishwasher back into the cabinet opening without scratching the floor.
      Ask FixBot
      • Reconnect any hardwired electrical connections in the same positions as before.
      • WARNING: Reinstall the junction box cover before restoring power.
      • Reinstall the top mounting screws or side mounting screws that secure the dishwasher to the cabinets.
      • Reinstall the lower access plate with its two screws.
      • Turn the dishwasher water supply back on if you shut it off.
      • Check that the drain line, water line, and electrical cable are routed properly and aren't pinched behind the dishwasher.
      Ask FixBot
      • Switch the dishwasher circuit breaker back on.
      • Check the control panel for the LC error.
      • The dishwasher has reset if the LC code clears and the normal preset time appears.
      • Monitor the dishwasher and the under-sink connections for leaks during the next wash.
      • If the LC code returns, moisture is still present, or a leak or clog still needs to be found.
      Ask FixBot
Keep the leak sensor and bottom pan dry, but don't ignore a recurring LC code. If the code returns, recheck the drain path, water intake, motor area, and under-sink connections for an active leak or clog. Repair didn't go as planned? Ask our Answers community for help.
eCuration
478,744 Reputation
396 Guides authored
0 Guide Comments
Past 24 Hours: 19
Past 7 Days: 169
Past 30 Days: 413
All Time: 717
