Video Guide
This guide was transcribed from a YouTube video.
Parts
Tools
Introduction
Go to step 1 ↓If your LG (or LG-built Kenmore) washing machine shows the LE error code, makes a grinding or bumping noise, and won’t spin properly, the washer is detecting a motor lock issue. This guide shows how to reset the control, check for physical obstructions, and diagnose and replace the rotor position sensor (RPS), which is a common cause of the LE code.
Step 1 Reset the washer to clear the LE code
Unplug the washing machine, and let it sit for 2–3 minutes.
Press and hold the power button for 5–10 seconds while the unit is unplugged.
Plug the washing machine back in, and confirm the LE code disappears.
Run a cycle to drain any water left in the drum.
Step 2 Check for a drum obstruction
Open the door, and spin the drum by hand to check for abnormal noise or sudden stopping.
Step 3 Remove the rear access panel
Move the washer to access the rear metal panel.
Use a Phillips screwdriver to remove the four screws from the rear panel.
Slide the rear panel off to expose the motor area.
Step 4 Remove the rotor bolt
Use a 17 mm socket wrench to turn the rotor bolt counterclockwise.
Hold the rotor in place so it doesn’t turn while you loosen the bolt.
Remove the rotor bolt fully once it’s loose.
Step 5 Remove the rotor
Pull the rotor straight off the shaft using equal pressure with both hands.
Wiggle the rotor gently and evenly on both sides while pulling if needed.
Step 6 Inspect the rotor hub and magnets
Inspect the rotor hub threads for severe wear.
Inspect the rotor magnets for smooth surfaces without wear, cracks, burning, damage, or obstructions.
Step 7 Remove the stator and disconnect its wiring
Use a 10 mm socket wrench to remove the six long screws holding the stator.
Hold the stator with one hand, and disconnect the two wire harnesses.
Step 8 Inspect the stator for damage
Inspect the stator magnet edges and the stator wiring for burn marks or damage.
Step 9 Remove the rotor position sensor
Locate the rotor position sensor on the inside of the stator ring.
Use a flat-bladed screwdriver to press in on the sensor’s retaining tab, and remove the sensor from the stator.
Step 10 Test the rotor position sensor with a multimeter
Set a multimeter to resistance (ohms).
Measure resistance between connector 5 and connector 1, and confirm the reading is 5–15 kΩ.
Measure resistance between connector 5 and connector 2, and confirm the reading matches and is 5–15 kΩ.
Step 11 Install the new rotor position sensor and check harnesses
Snap the new sensor onto the three outer pegs on the stator ring.
Snap the sensor onto the inner peg so it locks in place securely.
Inspect the stator wiring and harness connectors for frayed wires, damage, or separated connector wires.
Step 12 Reinstall the stator
Position the stator on the tub, and start two bolts by hand to hold it in place.
Thread the two bolts only partway so the stator can’t move.
Reconnect the two wire harnesses to the stator.
Use a 10 mm socket wrench to install the other four bolts, and fully tighten all six bolts.
Step 13 Reinstall the rotor and secure the bolt
Align the rotor hub threads with the tub shaft, and set the rotor onto the stator.
Press the rotor toward the tub if needed so the bolt can start threading into the shaft.
Apply five or six drops of blue threadlocker to the rotor bolt threads.
Use a 17 mm socket wrench to tighten the rotor bolt, then tap the wrench with a hammer a few times to ensure it’s tight.
Step 14 Reinstall the rear panel and test the washer
Slide the rear panel into place.
Use a Phillips screwdriver to install the four rear panel screws.
Move the washing machine back into place, plug it in, and confirm the hoses are connected.
Run a test cycle, and confirm the washer runs smoothly and spins properly without thunking noises.
Reinstall the rear panel and run a test cycle to confirm the LE code is cleared before returning the washer to service. Repair didn't go as planned? Ask our Answers community for help.
2 other people completed this guide.
3 Guide Comments
عندما يتعطل النظام الغسالة بمعناال جي إلي هوا الشريحة ما الحل
Make note your front loader lg washer direct drive doesn’t have a posion sensor it has coils
Beste Anleitung im Netz! Danke dafür. Bei mir war der Sensor defekt, obwhl die Messwerte des Sensors bei alt und neu gleich waren (warum auch immer). nach Tausch des Sensors, lief alles wieder normal. Vor allem der Text, der die Schritte erklärt, war eine große Hilfe. Nochmal danke!!
