How to Fix the Frigidaire Dryer E8C Error Code
Video Guide
This guide was transcribed from a YouTube video.
    • Stop using the dryer if it gets very hot, takes too long to dry, or shows the E8C error code.
    • Blocked venting can trap heat in the dryer and create a fire hazard.
    • Turn off the dryer, unplug it, and let it cool completely before inspecting or cleaning it.
    • If the dryer is a gas model, shut off the gas supply before moving it.
    • Wear work gloves when reaching behind or inside the dryer because sheet-metal edges can be sharp.
    Ask FixBot
    • Treat E8C as an overheating and airflow problem before replacing parts.
    • The error appears when the high-limit thermostat trips too many times during the selected cycle.
    • The control board sees those trips through the black J2-3 wire as a loss of voltage.
    • A dryer with this fault may run very hot and still take longer than normal to dry clothes.
    Ask FixBot
    • Use the thermostat system as your safety reference while troubleshooting.
    • The high-limit thermostat shuts off heat when the dryer gets too hot.
    • That thermostat resets after it cools.
    • The safety thermostat is the backup if the high-limit thermostat cannot protect the dryer.
    • The safety thermostat shuts the whole dryer down and does not reset after it cools.
    • Never bypass the high-limit or safety thermostat.
    Ask FixBot
    • Pull out the lint filter and remove all lint from the screen.
    • Look into the filter slot with a flashlight for packed lint.
    • Vacuum out any loose lint you can reach safely.
    • Reinstall the lint filter before running the dryer.
    • A clogged lint filter is one of the most common causes of E8C.
    Ask FixBot
    • Pull the dryer away from the wall only as far as the vent and utility lines allow.
    • Inspect the vent behind the dryer for crushed, kinked, or blocked sections.
    • Straighten any kinked venting and remove visible lint from the opening.
    • Do not push the dryer back far enough to crush the vent again.
    • Restricted venting can make the heating element run much hotter than normal.
    Ask FixBot
    • Go outside and find the vent hood where the dryer exhaust leaves the house.
    • Clear away lint, debris, or anything else that could stop the flap from opening.
    • Move the flap by hand to make sure it opens freely and closes again when released.
    • A restricted outside flap can trap heat in the dryer and trip the high-limit thermostat.
    Ask FixBot
    • Clean lint from the accessible vent path and from any reachable lint buildup inside the dryer.
    • Use a vacuum to remove loose lint from areas you can reach safely.
    • Use a dryer-vent brush to loosen lint inside vent sections you can reach safely.
    • Do not run the dryer until heavy lint buildup is removed.
    • Use the vent-cleaning guide if you need a more thorough cleaning walkthrough.
    Ask FixBot
    • Reconnect the vent, restore power, and turn the gas supply back on if the dryer uses gas.
    • Run a short heated cycle and check the outside vent hood.
    • Confirm that air is flowing out and that the outside flap opens while the dryer runs.
    • Stop the dryer if the cabinet becomes very hot or heat builds up around the back panel.
    • With clear venting, you should not feel severe hot spots on the back of the dryer.
    Ask FixBot
    • Do not bypass, jumper, or defeat the high-limit thermostat to keep the dryer running.
    • The thermostat is responding to overheating caused by restricted airflow.
    • Do not reset or replace a safety thermostat until you fix the lint or vent restriction that caused it to trip.
    • If E8C returns after the lint filter, venting, outside flap, and dryer interior are clean, stop using the dryer until the thermostat circuit is diagnosed.
    Ask FixBot
Run the dryer only after the lint filter, venting, outside flap, and inside lint buildup are clear. Repair didn't go as planned? Ask our Answers community for help.
eCuration
476,944 Reputation
385 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 46
All Time: 45
