How to Fix the Fit of Eyeglasses
    1. How to Fix the Fit of Eyeglasses, How to Fix the Fit of Eyeglasses: step 1, image 1 of 1
      • Assess the glasses and check the deformed areas (legs, temple tips, and nose).
      Ask FixBot
    2. How to Fix the Fit of Eyeglasses: step 2, image 1 of 1
      • Use a hair dryer to warm the temple tips.
      • Avoid overheating the frames. Moving the hair dryer ensures the heat is evenly distributed without damaging the plastic.
      Ask FixBot
    3. How to Fix the Fit of Eyeglasses: step 3, image 1 of 1
      • Gently bend and adjust the temple tips to your desired position.
      • Make sure the temple tips are bent just enough to fit securely behind your ears.
      Ask FixBot
    4. How to Fix the Fit of Eyeglasses: step 4, image 1 of 2 How to Fix the Fit of Eyeglasses: step 4, image 2 of 2
      • Use the hair dryer and pliers to adjust the legs of the eyeglasses.
      Ask FixBot
    5. How to Fix the Fit of Eyeglasses: step 5, image 1 of 2 How to Fix the Fit of Eyeglasses: step 5, image 2 of 2
      • Ensure the frame sits evenly and symmetrically on a flat surface.
      • If the frame does not sit evenly and wobbles, readjust the legs until satisfied.
      Ask FixBot
    6. How to Fix the Fit of Eyeglasses: step 6, image 1 of 2 How to Fix the Fit of Eyeglasses: step 6, image 2 of 2
      • Adjust the nose pads using your thumb and fingers without applying heat.
      • Heating the nose pads is not necessary since they are malleable enough to be bent with small amounts of pressure.
      • Be careful not to over-bend the nose pads, as they can break if too much pressure is applied.
      Ask FixBot
By following these steps, you can easily restore the fit of your eyeglasses for increased comfort and stability. Minor adjustments like these not only save you a trip to a repair shop but also allow you to make precise changes tailored to your fit preferences. Remember to handle each adjustment with care, especially when using heat on plastic frames and applying pressure to metal frames, to avoid damage. With a little patience, this process will have your glasses feeling as good as new, letting you see clearly and comfortably throughout the day.
Dino Espineli
154 Reputation
1 Guide authored
UC Davis, Team 1-3, Morris Fall 2024 Member of UC Davis, Team 1-3, Morris Fall 2024
UCD-MORRIS-F24S1G3
2 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 71
All Time: 1,029
