How to Fix the Bosch Dishwasher E25 Error Code
Video Guide
This guide was transcribed from a YouTube video.
    • Unplug the dishwasher from the wall outlet or switch off its circuit breaker before opening the sump or drain pipework.
    • Keep a bucket and sponge nearby if there is standing water in the bottom of the dishwasher.
    Ask FixBot
    • Open the door and roll the bottom tray straight out on its runners.
    • Pull the top cutlery tray outward until the front wheels reach the end stops.
    • Lift the tray over the end divot, move the second set of wheels over the stop, and set the tray on the floor.
    • Unload the top tray if it feels heavy.
    Ask FixBot
    • Find the round filter assembly in the bottom of the dishwasher tub.
    • Turn the filter counterclockwise a few turns until the catch releases.
    • Lift the whole filter assembly out of the sump.
    • A dirty filter can stop water draining and leave dishes dirty.
    Ask FixBot
    • Use a sponge to soak up the excess water in the sump.
    • Squeeze the water into a bucket and repeat until the sump is empty.
    • Removing the water gives clear access to the wastewater pump cover and impeller.
    Ask FixBot
    • Insert the bowl of a sturdy metal spoon behind the pump cover clip.
    • Lever the clip outward until it pops free.
    • Pull the cover upward with your fingers and slide it toward you.
    • Use a strong spoon because a flimsy spoon can bend.
    Ask FixBot
    • Look into the bottom of the pump opening for debris, dirt, or long hair.
    • Use a fingertip to gently turn the impeller and confirm it spins freely.
    • The pump area may contain sharp debris, so keep your fingers where you can see them.
    • Wear protective gloves if you need to remove sharp debris from the pump opening.
    • Remove any debris that could stop the impeller from spinning.
    • Slide the pump cover downward, push it inward, and listen for the clip to pop into place.
    Ask FixBot
    • Hold the dirty filter over a bin.
    • Use a brush to scrape as much debris and dirt from the filter as you can.
    • Don't rinse heavy food buildup into a sink, because it can block the sink drain.
    Ask FixBot
    • Fill a bowl with hot, soapy water.
    • Scrub the filter assembly with a brush until the mesh and plastic surfaces are clean.
    • Use dish soap to cut through greasy buildup.
    • If the filter parts separated during cleaning, push them back together until they clip into place.
    Ask FixBot
    • Place the clean filter assembly back into the sump.
    • Push it down gently and don't force it.
    • Turn the filter clockwise until it tightens and the two arrows line up.
    • The aligned arrows show the filter is locked in properly.
    Ask FixBot
    • Slide the bottom tray back into the dishwasher on its rollers.
    • Use two hands to guide the top tray back onto its runners.
    • Make sure the same height wheels are seated on both sides of the top tray.
    • The different height wheels let the top tray sit higher or lower, but both sides must match.
    Ask FixBot
    • If the dishwasher still doesn't drain, pull it out far enough to reach the drain hose at the back.
    • Keep the power disconnected and don't strain the hoses or power cord while moving the dishwasher.
    • Use a bucket and sponge, because water may spill from the hose.
    • Empty the drain hose into the bucket and check the hose end for obvious blockages.
    • Leave the hose resting in the bucket while you inspect the U-bend.
    Ask FixBot
    • Put a plastic tray under the U-bend pipework to catch water.
    • Undo the hand-tight plastic collars on the U-bend by hand.
    • Remove only the pipe section needed to check inside the U-bend.
    • Pour excess water into the sink and inspect the pipe for residue or buildup.
    • The U-bend is a common place for blockages because debris settles there.
    Ask FixBot
    • Refit the U-bend pipework to the wall connection.
    • Hand-tighten the plastic collars until they are snug.
    • Don't use pliers or overtighten the collars, because the plastic threads can be damaged.
    • Reconnect the dishwasher waste pump hose to the drain connection.
    • Do not leave the waste pump hose disconnected, or water will pour onto the floor during draining.
    • Wipe up spilled water before restoring power.
    • Plug the dishwasher back in or turn the circuit breaker back on.
    • Run a drain or rinse cycle and check that water drains without leaks.
    Ask FixBot
If the E25 error or drainage problem continues after the filter, impeller, drain hose, and U-bend are clear, the dishwasher may need further diagnosis of the drain system or pump. Repair didn't go as planned? Ask our Answers community for help.
eCuration
476,944 Reputation
385 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 39
Past 30 Days: 105
All Time: 143
