How to Fix an Unwinding Tape Measure
  1. How to Fix an Unwinding Tape Measure, How to Fix an Unwinding Tape Measure: step 1, image 1 of 1
    • Grab your broken tape measure and inspect so that it doesn't retract.
    • Make sure it is not locked.
    Ask FixBot
  2. How to Fix an Unwinding Tape Measure: step 2, image 1 of 2 How to Fix an Unwinding Tape Measure: step 2, image 2 of 2
    • Remove the four 3mm Phillips #1 screws on the case around the clip.
    • Remove the 3mm Phillips #1 screw from the center of the clip.
    Ask FixBot
  3. How to Fix an Unwinding Tape Measure: step 3, image 1 of 3 How to Fix an Unwinding Tape Measure: step 3, image 2 of 3 How to Fix an Unwinding Tape Measure: step 3, image 3 of 3
    • Separate the two halves of the case by pulling them apart.
    Ask FixBot
  4. How to Fix an Unwinding Tape Measure: step 4, image 1 of 2 How to Fix an Unwinding Tape Measure: step 4, image 2 of 2
    • Begin unwinding your tape measure until you get to the end of the tape.
    • Remember to be careful when retracting so that the spring doesn't come out or you hurt someone when the whole tape is out.
    Ask FixBot
  5. How to Fix an Unwinding Tape Measure: step 5, image 1 of 2 How to Fix an Unwinding Tape Measure: step 5, image 2 of 2
    • When the whole tape is out, slowly begin rolling it back in.
    • Roll it back in keeping your thumb firmly pressed on the wheel so that it goes back in smoothly and won't come out.
    • Once you start reaching the end, keep the tape straight with your thumb so that it retracts with no inconveniences.
    Ask FixBot
  6. How to Fix an Unwinding Tape Measure: step 6, image 1 of 2 How to Fix an Unwinding Tape Measure: step 6, image 2 of 2
    • Once you have rolled the tape in again, place the top back on making sure the tape doesn't come out or roll out by itself.
    • Remember to keep your thumb on the wheel as you put on the top so that it doesn't come out and hurt anyone!
    Ask FixBot
  7. How to Fix an Unwinding Tape Measure: step 7, image 1 of 1
    • Begin placing the screws back in to their respective places and screwing them back in tightly.
    • Do this as you apply pressure on the top so that no parts come out.
    Ask FixBot
  8. How to Fix an Unwinding Tape Measure: step 8, image 1 of 1
    • Once your screws are back on, check your tape measure to see if it works properly or not.
    • If it isn't working the way you wanted to, repeat steps 2-7.
    Ask FixBot
6 other people completed this guide.
3 Guide Comments
Wat te doen als de veer van het oprolmechanisme los is gekomen?
Adri - Reply Share
Heres the real solution for a tape that does not retract:
Disassemble until step 3
Roll out a bit of the tape
Roll it around the round thing with the spring in it once or twice (depends on how much retension you need) While holding the round thing in its position. Then reassemble. Done
Mortan Media - Reply Share
Ben een uur bezig geweest met een simpele 2m' rolmaat van SantYau. Het wilde maar niet lukken. Toen voor 1/10e van m'n uurloon een nieuwe gekocht.
John Voogt - Reply Share
Past 24 Hours: 36
Past 7 Days: 271
Past 30 Days: 1,216
All Time: 77,145
