How to Fix an Overwound Music Box
Views: 95K
View statistics:
Past 24 Hours:
26
Past 7 Days:
173
Past 30 Days:
823
All Time:
94,896
Comments: 31
9 comments on steps, 22 guide comments.
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The extensive use of a music box and winding the main spring excessively will lead it to fail. This failure is caused because the music box mechanism gets jammed, and then, you are no longer able to enjoy its beautiful tunes.
However, the music box that you have loved and cherished over the years can still be salvaged. This guide will help restore your music box to mint condition with some easy-to-do steps that will assist the restoration of the mechanism.
With minimal effort your music box will resume entertaining you with its beautiful tunes.
Tools
    1. How to Fix an Overwound Music Box, How to Fix an Overwound Music Box: step 1, image 1 of 3 How to Fix an Overwound Music Box, How to Fix an Overwound Music Box: step 1, image 2 of 3 How to Fix an Overwound Music Box, How to Fix an Overwound Music Box: step 1, image 3 of 3
      • Use a Phillips #0 screwdriver to unscrew the screws at the base of the music box.
      • Remove the outer casing and isolate the mechanism.
      Ask FixBot
    2. How to Fix an Overwound Music Box: step 2, image 1 of 2 How to Fix an Overwound Music Box: step 2, image 2 of 2
      • Gently wipe the mechanism with a cloth to get rid of any settled dust particles.
      • Make sure you wipe all the open and accessible surfaces of the mechanism.
      • Be extremely careful when cleaning the comb and the drum. The comb is delicate and can break when too much pressure is applied. The threads of the cloth can get stuck in the pins of the drum.
      Ask FixBot
    3. How to Fix an Overwound Music Box: step 3, image 1 of 2 How to Fix an Overwound Music Box: step 3, image 2 of 2
      • Slowly turn the winding key in the opposite direction to release the tension built-up in the spring.
      Ask FixBot
    4. How to Fix an Overwound Music Box: step 4, image 1 of 2 How to Fix an Overwound Music Box: step 4, image 2 of 2
      • Tap the base of the mechanism a few times to release the governor assembly.
      Ask FixBot
    5. How to Fix an Overwound Music Box: step 5, image 1 of 2 How to Fix an Overwound Music Box: step 5, image 2 of 2
      • Gently push the governor fan with your fingertip to assist its spin movement.
      Ask FixBot
    6. How to Fix an Overwound Music Box: step 6, image 1 of 3 How to Fix an Overwound Music Box: step 6, image 2 of 3 How to Fix an Overwound Music Box: step 6, image 3 of 3
      • Use a toothpick to reach the flywheel.
      • Push the toothpick forward to spin the flywheel and assist its rotation.
      Ask FixBot
    7. How to Fix an Overwound Music Box: step 7, image 1 of 2 How to Fix an Overwound Music Box: step 7, image 2 of 2
      • Using a narrow nozzle, spray some WD-40 on the spring housing gear and the governor.
      • The nozzle is pointed at the spring housing gear in the first photo, and in the second photo the nozzle is pointed at the governor.
      • In case you don't have a narrow nozzle, you can add a few drops of WD-40 using any other small quantity dropper.
      Ask FixBot
    8. How to Fix an Overwound Music Box: step 8, image 1 of 1
      • Keep the music box playing for a few minutes after it restarts.
      Ask FixBot
13 other people completed this guide.
Gaurangi Sawant
535 Reputation
1 Guide authored
22 Guide Comments
Very clear instructions. However my music mechanism has glue keeping it firmly to the base of porcelain box. How to release it so I can follow your instructions to repair it. It's a Lenox figurine of baby sitting & spinning on a Christmas gift. White with gold accents
Thank you
Beachbabe - Reply Share
You should be able to loosen the glue with denatured alcohol, acetone or a heat gun, or a hair dryer if you don't have one. Then gently remove the music box. When your finished you can reglue the music box into the figurine with a household glue like E6000.
Kathy - Reply Share
Mine is in a stuffed animal and i dont want to have to break the plush to fix it
Idk - Reply Share
With stuffed animals, use a seam ripper to undo the threads of where the fur is sewn, then sew it back together after the repair
[deleted] - Reply Share
I would add that unless it is a swiss mechanism you would be better off replacing. I do not usually restore these plastic ones.
musicboxman63 - Reply Share
Past 24 Hours: 26
Past 7 Days: 173
Past 30 Days: 823
All Time: 94,896
