How to Fix an Armhole Gape
Views: 1.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
101
All Time:
1,064
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 35 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Armhole gapes are loose flaps that make the shirt look weird. They are usually placed underneath the arm. Gapes can come across other parts of the clothing. Repairing armhole gapes is a convenient way to prevent the clothing from looking weird and keeping the nice and fitted shape of the body. It can also help cover more.
    1. How to Fix an Armhole Gape, How to Fix an Armhole Gape: step 1, image 1 of 1
      • Gather the supplies needed.
      Ask FixBot
    2. How to Fix an Armhole Gape: step 2, image 1 of 2 How to Fix an Armhole Gape: step 2, image 2 of 2
      • Grab your measuring tape.
      • Measure from the middle of the breast to the under arm part.
      Ask FixBot
    3. How to Fix an Armhole Gape: step 3, image 1 of 3 How to Fix an Armhole Gape: step 3, image 2 of 3 How to Fix an Armhole Gape: step 3, image 3 of 3
      • Mark the middle of the breast and at the end where the under arm is. (Slide one and two)
      • Mark how big you want to close the gape. (Depends on how big your armhole gape is) (Slide three)
      • Mine was about 0.5 inches. (Slide three)
      Ask FixBot
    4. How to Fix an Armhole Gape: step 4, image 1 of 3 How to Fix an Armhole Gape: step 4, image 2 of 3 How to Fix an Armhole Gape: step 4, image 3 of 3
      • Connect both of the dots from the breast to the two dots you marked near the underarm.
      • Fold the second line you created and pin them to keep it coming from getting undone. (Slides two and three)
      Ask FixBot
    5. How to Fix an Armhole Gape: step 5, image 1 of 1
      • Sew across.
      • I used a straight sew stitch by hand (you can use a sewing machine and any stitch)
      Ask FixBot
    6. How to Fix an Armhole Gape: step 6, image 1 of 1
      • Lastly, cut the access off.
      • Then flip it inside out.
      • And your done!
      Ask FixBot
Thank you for taking the time to read this.
Danielle Fontanos
133 Reputation
1 Guide authored
1 Guide Comment
Would this help if it's not really gaping loosely but showing a bit of bra right in front of under arm? If not can you recommend a solution to this problem?
Oveta Alexander - Reply Share
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 101
All Time: 1,064
