How to Fix a Tunneling Candle
    1. How to Fix a Tunneling Candle, How to Fix a Tunneling Candle: step 1, image 1 of 3 How to Fix a Tunneling Candle, How to Fix a Tunneling Candle: step 1, image 2 of 3 How to Fix a Tunneling Candle, How to Fix a Tunneling Candle: step 1, image 3 of 3
      • Fill any kind of dish with hot water.
      • Add any brand of dish soap or hand soap to the water.
      • Mix the soap with water using a spoon.
      Ask FixBot
    2. How to Fix a Tunneling Candle: step 2, image 1 of 2 How to Fix a Tunneling Candle: step 2, image 2 of 2
      • Place the candle inside the mix of water and soap.
      • Let the jar soak inside the pot.
      • Make sure the area on the jar that has a label is completely soaked.
      • After 5 to 10 minutes, remove the candle from the dish.
      Ask FixBot
    3. How to Fix a Tunneling Candle: step 3, image 1 of 1
      • Use a sponge to wash and remove the label from the jar.
      • Removing the label helps you have a cleaner fix as it prevents the label from peeling off inside the boiling water and damaging your pot in future steps.
      Ask FixBot
    4. How to Fix a Tunneling Candle: step 4, image 1 of 3 How to Fix a Tunneling Candle: step 4, image 2 of 3 How to Fix a Tunneling Candle: step 4, image 3 of 3
      • Fill another pot with water and place it on the stove.
      • Turn the stove to high heat.
      • Wait until the water is simmering.
      Ask FixBot
    5. How to Fix a Tunneling Candle: step 5, image 1 of 3 How to Fix a Tunneling Candle: step 5, image 2 of 3 How to Fix a Tunneling Candle: step 5, image 3 of 3
      • Use oven mitts to place the candle inside the pot.
      • Wait 15 to 30 minutes for the wax to be fully melted.
      Ask FixBot
    6. How to Fix a Tunneling Candle: step 6, image 1 of 3 How to Fix a Tunneling Candle: step 6, image 2 of 3 How to Fix a Tunneling Candle: step 6, image 3 of 3
      • While waiting for the wax to melt, grab two coffee stir sticks or similar objects, and tape them into a cross.
      • In this guide, I am using incense sticks.
      Ask FixBot
    7. How to Fix a Tunneling Candle: step 7, image 1 of 3 How to Fix a Tunneling Candle: step 7, image 2 of 3 How to Fix a Tunneling Candle: step 7, image 3 of 3
      • Take the candle out of the pot using oven mitts.
      • Place the melted candle on a flat surface.
      • Remember to turn off the stove.
      Ask FixBot
    8. How to Fix a Tunneling Candle: step 8, image 1 of 2 How to Fix a Tunneling Candle: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to grab and pull out the burnt wick of the candle.
      • Do not touch the hot wax with your fingers; use tweezers.
      Ask FixBot
    9. How to Fix a Tunneling Candle: step 9, image 1 of 3 How to Fix a Tunneling Candle: step 9, image 2 of 3 How to Fix a Tunneling Candle: step 9, image 3 of 3
      • Place the cross that you made from the sticks on the edges of the candle jar.
      • Insert two new candle wicks inside the wax from the metal side.
      • Make sure the wicks are not close together.
      • Twist the wick around the sticks to prevent them from moving.
      Ask FixBot
    10. How to Fix a Tunneling Candle: step 10, image 1 of 3 How to Fix a Tunneling Candle: step 10, image 2 of 3 How to Fix a Tunneling Candle: step 10, image 3 of 3
      • Wait for the wax to harden and remove the sticks.
      • Trim the candle wick to 1/4 inch.
      • You have fixed your tunneling candle.
      Ask FixBot
Finish Line
2 other people completed this guide.
[deleted]
245 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 90
All Time: 2,046
