Introduction
Crocs and other plastic slip-on shoes have been popular for what feels like forever. Don’t let one tear turn your favorite shoes into garbage. Repair a common tear on your plastic shoe strap and bring your Crocs back to life.
This repair uses common household items that most of us have lying around. Be sure to use glue designed for bonding plastics, preferably waterproof. As long as your shoe only has tears, strong glue will work well to unite the material once again. If any portion of the strap material is missing, this won't be the best repair guide for your shoe.
Before you begin this repair, make sure to have proper personal protective gear to protect your skin from any strong glue that would bond it instantly, like super glue. If using epoxy or resin-type adhesive, be sure to work in a well-ventilated space.
Use rubbing alcohol and a paper towel to clean the surface of the shoe where the repair will be done.
Make sure to allow the glue to set to whatever time specifications on the specific glue you use- then go give your shoes a second life!
