How to Fix a Thrustmaster Eswap X Pro Controller Trigger
  1. How to Fix a Thrustmaster Eswap X Pro Controller Trigger, How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 1, image 1 of 2 How to Fix a Thrustmaster Eswap X Pro Controller Trigger, How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 1, image 2 of 2
    • Flip the controller so the backside is facing up.
    • Flip both of the switches away from the center.
    Ask FixBot
  2. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 2, image 1 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 2, image 2 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 2, image 3 of 3
    • Flip the controller over so the top is facing up.
    • Pull out both the joystick and the directional pad modules.
    Ask FixBot
  3. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 3, image 1 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 3, image 2 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 3, image 3 of 3
    • Flip the controller over again so the backside is facing up.
    • Use a spudger to remove five rubber screw covers.
    Ask FixBot
  4. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 4, image 1 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 4, image 2 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 4, image 3 of 3
    • Use a Phillips #1 screwdriver to remove each of the 4.0 mm exposed screws.
    Ask FixBot
  5. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 5, image 1 of 2 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 5, image 2 of 2
    • Use a Phillips #1 screwdriver to loosen the captive screw and remove the trigger button.
    Ask FixBot
  6. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 6, image 1 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 6, image 2 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 6, image 3 of 3
    • Rotate the controller 90 degrees.
    • Pull off the magnetic side cover.
    Ask FixBot
  7. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 7, image 1 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 7, image 2 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 7, image 3 of 3
    • Lift the back cover slightly from where you removed the trigger button.
    • Use a Q-tip dipped with isopropyl alcohol to clean the surrounding area.
    • Additionally, wipe down the top face of the trigger with a Q-tip.
    Ask FixBot
  8. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 8, image 1 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 8, image 2 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 8, image 3 of 3
    • Reattach the trigger button onto the controller.
    • Use a Phillips #1 screwdriver to tighten the screw securing trigger button.
    Ask FixBot
  9. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 9, image 1 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 9, image 2 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 9, image 3 of 3
    • Use a Phillips #1 screwdriver to reattach the 4.0 mm screws to the back of the controller.
    Ask FixBot
  10. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 10, image 1 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 10, image 2 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 10, image 3 of 3
    • Notice that the notches on the rubber covers correspond with the notches on the screw hole.
    • Reattach the rubber covers above the screws.
    Ask FixBot
  11. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 11, image 1 of 1
    • Place the joystick and the directional pad modules back in their respective spots.
    Ask FixBot
  12. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 12, image 1 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 12, image 2 of 3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: step 12, image 3 of 3
    • Reattach the magnetic side cover.
    • The controller is fixed!
    Ask FixBot
4 other people completed this guide.
Laurence Chan
296 Reputation
1 Guide authored
UC Davis, Team 2-3, Morris Winter 2023 Member of UC Davis, Team 2-3, Morris Winter 2023
UCD-MORRIS-W23S2G3
2 Members
1 Guide authored
4 Guide Comments
The problem is it keeps happening after doing all these steps. is there any way or parts to replace the trigger sensor completely? Possibly with a nice hall effect sensor?
John Addington - Reply Share
You can remove the lever bar that goes from the screw to the sensor (the one you see on Step 7)
Spray a small amount of WD40 on the sensor and use a prong to rotate the part on its full range of motion several times, that will clean up the contact inside and it completely fixed the jitter on mine.
Alex L - Reply Share
hi, i made an account here just to say this worked for me but on the thrustmaster eswap S pro controller, it's almost identical aside from the cover panels
Anna Fiore - Reply Share
so to repair mine, I did a couple additional things :
- step 3 & 4 : I unscrewed all 7 screws (careful though some stuff can tumble it seems)
- on the image of step 7b you can see a small screw above the Q-tip, I unscrewed this ( Phillips #0 )
- removed the lever
- carefully pushed the trigger mechanism to the side to "fully open it"
- at this point I had full access to the sensor & to the spring on the rotating part of the trigger
- cleaned both
- reassembled everything ( be gentle with the screwing of the Phillips #0 screw )
DONE.
Thanks for the guide.
Whismerhill - Reply Share
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 111
All Time: 5,159
