How to Fix a Stuck Quarter in a Candy Machine
    1. How to Fix a Stuck Quarter in a  Candy Machine, How to Fix a Stuck Quarter in a  Candy Machine: step 1, image 1 of 3 How to Fix a Stuck Quarter in a  Candy Machine, How to Fix a Stuck Quarter in a  Candy Machine: step 1, image 2 of 3 How to Fix a Stuck Quarter in a  Candy Machine, How to Fix a Stuck Quarter in a  Candy Machine: step 1, image 3 of 3
      • Remove the lid of the machine.
      • Remove candy from container and place aside in a bowl.
      Ask FixBot
    2. How to Fix a Stuck Quarter in a  Candy Machine: step 2, image 1 of 3 How to Fix a Stuck Quarter in a  Candy Machine: step 2, image 2 of 3 How to Fix a Stuck Quarter in a  Candy Machine: step 2, image 3 of 3
      • Using a flathead screwdriver unscrew the four 10mm corner screws.
      • Remove the plastic container and set it aside.
      Ask FixBot
    3. How to Fix a Stuck Quarter in a  Candy Machine: step 3, image 1 of 2 How to Fix a Stuck Quarter in a  Candy Machine: step 3, image 2 of 2
      • Using a Phillips #1 screwdriver remove the two 15mm screws that are marked in the photo.
      Ask FixBot
    4. How to Fix a Stuck Quarter in a  Candy Machine: step 4, image 1 of 2 How to Fix a Stuck Quarter in a  Candy Machine: step 4, image 2 of 2
      • Remove the inner mechanisms by sliding them up and off the metal rod.
      Ask FixBot
    5. How to Fix a Stuck Quarter in a  Candy Machine: step 5, image 1 of 2 How to Fix a Stuck Quarter in a  Candy Machine: step 5, image 2 of 2
      • Remove the metal top with both hands on the sides.
      • Lift up, sliding it up and off the metal rod.
      Ask FixBot
    6. How to Fix a Stuck Quarter in a  Candy Machine: step 6, image 1 of 3 How to Fix a Stuck Quarter in a  Candy Machine: step 6, image 2 of 3 How to Fix a Stuck Quarter in a  Candy Machine: step 6, image 3 of 3
      • Now you can see into the inner mechanisms.
      • Locate the stuck quarter and try to remove it.
      • For better access, lift up the left hinge to release the entire mechanism.
      Ask FixBot
    7. How to Fix a Stuck Quarter in a  Candy Machine: step 7, image 1 of 2 How to Fix a Stuck Quarter in a  Candy Machine: step 7, image 2 of 2
      • Remove the inner mechanism by pulling out one side before sliding out the whole mechanism.
      Ask FixBot
    8. How to Fix a Stuck Quarter in a  Candy Machine: step 8, image 1 of 2 How to Fix a Stuck Quarter in a  Candy Machine: step 8, image 2 of 2
      • Find the stuck quarter in the mechanism.
      • Remove the quarter with your hands by simply pulling (use a plier if needed).
      Ask FixBot
    9. How to Fix a Stuck Quarter in a  Candy Machine: step 9, image 1 of 2 How to Fix a Stuck Quarter in a  Candy Machine: step 9, image 2 of 2
      • Slide the mechanism back in, right side in first followed by left.
      • Lock the mechanism in place by sliding the hinge lock back down.
      Ask FixBot
    10. How to Fix a Stuck Quarter in a  Candy Machine: step 10, image 1 of 2 How to Fix a Stuck Quarter in a  Candy Machine: step 10, image 2 of 2
      • Return the metal top by sliding it back down the metal rod.
      • To secure the metal top back into place pull it forward so it covers the front of the machine.
      Ask FixBot
    11. How to Fix a Stuck Quarter in a  Candy Machine: step 11, image 1 of 3 How to Fix a Stuck Quarter in a  Candy Machine: step 11, image 2 of 3 How to Fix a Stuck Quarter in a  Candy Machine: step 11, image 3 of 3
      • Slide the rotation mechanism back down so it sits with one of the three holes is fully over the hole.
      • Slide down the cover mechanism so it aligns with the screw holes.
      • Use a phillips head screwdriver to screw down the two side screws.
      Ask FixBot
    12. How to Fix a Stuck Quarter in a  Candy Machine: step 12, image 1 of 2 How to Fix a Stuck Quarter in a  Candy Machine: step 12, image 2 of 2
      • Replace the plastic container so it aligns with the four screw holes.
      • Replace the four screws using a flat head screwdriver.
      Ask FixBot
    13. How to Fix a Stuck Quarter in a  Candy Machine: step 13, image 1 of 2 How to Fix a Stuck Quarter in a  Candy Machine: step 13, image 2 of 2
      • Replace the candy and the lid.
      • Enjoy your sweet tooth adventures.
      Ask FixBot
I hope this guide helps you understand how to fix and change your candy machine, enjoy your candy!
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 64
All Time: 2,877
