How to Fix a Slipping Violin Peg
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
27
Past 30 Days:
138
All Time:
1,135
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
If your violin is not producing the desired tune due to a loose string that will not tighten despite adjustment, use this guide to fix your loose violin peg.
Each string on the violin is attached to a peg that allows you to tune it. If your string is continually loose, then a loose peg is the issue. Rewinding the string completely and administering peg compound ensures the correct position to hold the peg in place in order for your violin to fully function. Using one of these methods over the other can also serve as a solution; however, it is best to do both.
Tools
    1. How to Fix a Slipping Violin Peg, How to Fix a Slipping Violin Peg: step 1, image 1 of 3 How to Fix a Slipping Violin Peg, How to Fix a Slipping Violin Peg: step 1, image 2 of 3 How to Fix a Slipping Violin Peg, How to Fix a Slipping Violin Peg: step 1, image 3 of 3
      • Completely unwind the string affected by the loose peg.
      • Turn the peg clockwise for strings G and D and counterclockwise for strings A and E.
      Ask FixBot
    2. How to Fix a Slipping Violin Peg: step 2, image 1 of 1
      • Slide the peg out towards you to remove it from the pegbox.
      • The pegbox contains the holes that the pegs go into.
      Ask FixBot
    3. How to Fix a Slipping Violin Peg: step 3, image 1 of 2 How to Fix a Slipping Violin Peg: step 3, image 2 of 2
      • Locate the points on the peg that come into contact with the pegbox.
      • Rub the peg compound all the way around the peg on the points that contact the pegbox.
      Ask FixBot
    4. How to Fix a Slipping Violin Peg: step 4, image 1 of 3 How to Fix a Slipping Violin Peg: step 4, image 2 of 3 How to Fix a Slipping Violin Peg: step 4, image 3 of 3
      • Reinsert the peg by pushing inwards.
      • Turn the peg counterclockwise or clockwise to evenly distribute the compound.
      Ask FixBot
    5. How to Fix a Slipping Violin Peg: step 5, image 1 of 2 How to Fix a Slipping Violin Peg: step 5, image 2 of 2
      • Wipe away the excess compound that is outside of the pegbox with a cloth or paper towel.
      Ask FixBot
    6. How to Fix a Slipping Violin Peg: step 6, image 1 of 3 How to Fix a Slipping Violin Peg: step 6, image 2 of 3 How to Fix a Slipping Violin Peg: step 6, image 3 of 3
      • Locate the hole on the peg and insert the string through it.
      • Tightly angle the string away from the peg head with one hand, while turning the peg toward the scroll with the other hand.
      • The scroll is the woodcarving at the top of the violin.
      • After one or two turns, angle the string toward the peg head (vertical alignment).
      Ask FixBot
    7. How to Fix a Slipping Violin Peg: step 7, image 1 of 2 How to Fix a Slipping Violin Peg: step 7, image 2 of 2
      • Tune the string.
      • For strings A and E, tightly turn the peg clockwise, and for strings G and D, turn the peg counterclockwise.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Be advised that steps 5 and 7 are optional.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 138
All Time: 1,135
