How to Fix a Ripped Necktie Seam
  1. How to Fix a Ripped Necktie Seam, Ripped Seam: step 1, image 1 of 1
    • Iron the area of the necktie that is ripped.
    • Ironing the necktie allows for clean lines and no wrinkles in the fabric.
    • When ironing, be careful not to burn yourself.
    Ask FixBot
  2. How to Fix a Ripped Necktie Seam: step 2, image 1 of 1
    • Position your tie with ripped seam facing up.
    Ask FixBot
  3. How to Fix a Ripped Necktie Seam: step 3, image 1 of 1
    • Gather your thread and scissors.
    • Cut to desired length.
    • Make sure your thread matches the color of your tie.
    Ask FixBot
  4. How to Fix a Ripped Necktie Seam: step 4, image 1 of 2 How to Fix a Ripped Necktie Seam: step 4, image 2 of 2
    • Gather your cut thread and needle.
    • Loop your thread through the eye of the needle.
    • Pull the thread until it is even on both ends.
    • Be careful of sharp needle.
    Ask FixBot
  5. How to Fix a Ripped Necktie Seam: step 5, image 1 of 1
    • Tie the end of the thread with a knot.
    Ask FixBot
  6. How to Fix a Ripped Necktie Seam: step 6, image 1 of 3 How to Fix a Ripped Necktie Seam: step 6, image 2 of 3 How to Fix a Ripped Necktie Seam: step 6, image 3 of 3
    • Poke your needle from the inside of the tie.
    • Pull the thread all the way through until it reaches the tied knot.
    • Leave about 1/4 inches from the original hole.
    • Poke your needle from the outside of the tie and pull thread until knot.
    • Be careful of sharp needle going in and out of fabric
    Ask FixBot
  7. How to Fix a Ripped Necktie Seam: step 7, image 1 of 3 How to Fix a Ripped Necktie Seam: step 7, image 2 of 3 How to Fix a Ripped Necktie Seam: step 7, image 3 of 3
    • Repeat the sewing pattern until you reach the end.
    • Make sure your final thread is through the inside of tie.
    Ask FixBot
  8. How to Fix a Ripped Necktie Seam: step 8, image 1 of 2 How to Fix a Ripped Necktie Seam: step 8, image 2 of 2
    • Once the entire seam has been sewn, create a loop with the thread.
    • To tie a knot, bring your needle through the loop and pull.
    • Repeat the knot 2-3 more times.
    • Make sure the knot is flat against the fabric.
    Ask FixBot
  9. How to Fix a Ripped Necktie Seam: step 9, image 1 of 2 How to Fix a Ripped Necktie Seam: step 9, image 2 of 2
    • Cut off any excess thread.
    • Do not cut too close to knot or it may unravel.
    Ask FixBot
  10. How to Fix a Ripped Necktie Seam: step 10, image 1 of 1
    • (Optional) Iron over seam for better results.
    Ask FixBot
Beverly Fan
196 Reputation
1 Guide authored
UC Davis, Team 2-4, Andersen Winter 2023 Member of UC Davis, Team 2-4, Andersen Winter 2023
UCD-ANDERSEN-W23S2G4
3 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 137
All Time: 3,247
