How to Fix a Rattling Door
    1. How to Fix a Rattling Door, How to Fix a Rattling Door: step 1, image 1 of 3 How to Fix a Rattling Door, How to Fix a Rattling Door: step 1, image 2 of 3 How to Fix a Rattling Door, How to Fix a Rattling Door: step 1, image 3 of 3
      • Remove the strike plate on the door by unscrewing the screws that attach it to the door frame.
      • The type of screwdriver you need depends on the type of screws that hold your strike plate in your door.
      Ask FixBot
    2. How to Fix a Rattling Door: step 2, image 1 of 2 How to Fix a Rattling Door: step 2, image 2 of 2
      • Take the strike plate and put it in your hand. Using the pliers in your other hand, bend the metal tab toward the flat side of the strike plate.
      Ask FixBot
    3. How to Fix a Rattling Door: step 3, image 1 of 2 How to Fix a Rattling Door: step 3, image 2 of 2
      • Place the strike plate back on the door frame and tighten the screws.
      Ask FixBot
Close your door and shake it back and forth to see if it is still loose. Repeat the guide steps as necessary.
2 other people completed this guide.
Sara Novell
218 Reputation
1 Guide authored
Cal Poly, Team 30-4, Green Spring 2015 Member of Cal Poly, Team 30-4, Green Spring 2015
CPSU-GREEN-S15S30G4
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 27
Past 30 Days: 185
All Time: 41,160
