How to Fix a Papasan Chair Base
    1. How to Fix a Papasan Chair Base, How to Fix a Papasan Chair Base: step 1, image 1 of 2 How to Fix a Papasan Chair Base, How to Fix a Papasan Chair Base: step 1, image 2 of 2
      • Remove and save rattan from broken sections.
      Ask FixBot
    2. How to Fix a Papasan Chair Base: step 2, image 1 of 1
      • Remove old nails from the sections that have separated. Pliers may be helpful for nails that are hard to reach with the claw of a hammer.
      Ask FixBot
    3. How to Fix a Papasan Chair Base: step 3, image 1 of 2 How to Fix a Papasan Chair Base: step 3, image 2 of 2
      • Glue the split wood pieces together, clamp, and let them dry.
      Ask FixBot
    4. How to Fix a Papasan Chair Base: step 4, image 1 of 1
      • Nail the thin decorative wood pieces to the larger sections of the frame.
      Ask FixBot
    5. How to Fix a Papasan Chair Base: step 5, image 1 of 1
      • Screw the circular base and upper to the vertical supports that have become disconnected.
      Ask FixBot
    6. How to Fix a Papasan Chair Base: step 6, image 1 of 1
      • Screw together two ends of the circular part of the frame. Align the screw to be perpendicular to the seam where the two ends connect.
      Ask FixBot
    7. How to Fix a Papasan Chair Base: step 7, image 1 of 2 How to Fix a Papasan Chair Base: step 7, image 2 of 2
      • Nail down one side of the rattan and re-wrap it. Finish by nailing down the other end of the rattan to secure it.
      Ask FixBot
Following these steps will restore your papasan chair to working order.
6 other people completed this guide.
3 Guide Comments
What screw you used? Screw dimensions?
Lourdes Diaz - Reply Share
easy peasy…thanks
Katherine Elaine - Reply Share
Were u would u recommend get the wicker to wrap chairs , at???
Thanks in advance!!!
Carrmone Bears - Reply Share
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 135
All Time: 22,774
