How to Fix a Loose-Fitting Lifting Belt
    1. How to Fix a Loose-Fitting Lifting Belt, How to Fix a Loose-Fitting Lifting Belt: step 1, image 1 of 1
      • Grab the lifting belt with the latch facing you.
      Ask FixBot
    2. How to Fix a Loose-Fitting Lifting Belt: step 2, image 1 of 1
      • Flip over the lifting belt, locating the back side of the latch.
      Ask FixBot
    3. How to Fix a Loose-Fitting Lifting Belt: step 3, image 1 of 3 How to Fix a Loose-Fitting Lifting Belt: step 3, image 2 of 3 How to Fix a Loose-Fitting Lifting Belt: step 3, image 3 of 3
      • In a counter-clockwise rotation, unscrew both of the screws holding the latch in place.
      Ask FixBot
    4. How to Fix a Loose-Fitting Lifting Belt: step 4, image 1 of 3 How to Fix a Loose-Fitting Lifting Belt: step 4, image 2 of 3 How to Fix a Loose-Fitting Lifting Belt: step 4, image 3 of 3
      • Once the screws have been removed, remove both sides of the latch from the belt.
      Ask FixBot
    5. How to Fix a Loose-Fitting Lifting Belt: step 5, image 1 of 2 How to Fix a Loose-Fitting Lifting Belt: step 5, image 2 of 2
      • Align the latch to the corresponding holes for the desired fit.
      • Make sure to align both sides of the latch to the same holes.
      Ask FixBot
    6. How to Fix a Loose-Fitting Lifting Belt: step 6, image 1 of 2 How to Fix a Loose-Fitting Lifting Belt: step 6, image 2 of 2
      • In a clockwise rotation, screw both of the screws securely in place.
      Ask FixBot
    7. How to Fix a Loose-Fitting Lifting Belt: step 7, image 1 of 2 How to Fix a Loose-Fitting Lifting Belt: step 7, image 2 of 2
      • Once screws have been secured, attach the latch and secure the belt.
      Ask FixBot
Samuel Garibay
147 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 61
All Time: 326
