How to Fix a Loose Oven Handle
Views: 54K
View statistics:
Past 24 Hours:
14
Past 7 Days:
126
Past 30 Days:
421
All Time:
53,540
Comments: 7
4 comments on steps, 3 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Before you begin:
For this fix, you would need to find a specialized screwdriver that would fit into you oven door handle screws. Have a damp cloth at hand if the screws are needed to be cleaned. If during your observation you notice that the screws are damaged you may need to buy new ones.
Tools
    1. How to Fix a Loose Oven Handle, How to Fix a Loose Oven Handle: step 1, image 1 of 2 How to Fix a Loose Oven Handle, How to Fix a Loose Oven Handle: step 1, image 2 of 2
      • Open the oven and unlock hinges that are located at the bottom of each side of the oven.
      Ask FixBot
    2. How to Fix a Loose Oven Handle: step 2, image 1 of 2 How to Fix a Loose Oven Handle: step 2, image 2 of 2
      • Lift the door up and detach from the oven.
      • Place the door on the floor or any other flat surface.
      Ask FixBot
    3. How to Fix a Loose Oven Handle: step 3, image 1 of 2 How to Fix a Loose Oven Handle: step 3, image 2 of 2
      • Unfasten the top 2 screws of the inside of the door ( the ones holding the handle).
      • For this specific oven, a Phillips #0 screwdriver was used. Make sure to check which screw driver fits your oven screws.
      Ask FixBot
    4. How to Fix a Loose Oven Handle: step 4, image 1 of 1
      • Observe the screws.
      • If rusty, cleanse them. If damaged, replace with new ones.
      Ask FixBot
    5. How to Fix a Loose Oven Handle: step 5, image 1 of 1
      • Reset and fasten the screws back in tightly.
      Ask FixBot
    6. How to Fix a Loose Oven Handle: step 6, image 1 of 2 How to Fix a Loose Oven Handle: step 6, image 2 of 2
      • Place the door back to the oven.
      • Refasten the hinges.
      Ask FixBot
    7. How to Fix a Loose Oven Handle: step 7, image 1 of 1
      • Test the handle
      Ask FixBot
5 other people completed this guide.
3 Guide Comments
I'm glad to hear that you found the article informative! My goal is to provide accurate and helpful information to anyone who asks. If you have any more questions or topics you'd like to learn about, feel free to ask!
Ava Dave - Reply Share
δεν κλείνει καλά η πόρτα της κουζίνας. αφήνει κενό επάνω.
Dimitris Georg - Reply Share
What would I wrap around screw to make a tighter connection; plumber tape, string, super glue?
stevereicher - Reply Share
Past 24 Hours: 14
Past 7 Days: 126
Past 30 Days: 421
All Time: 53,540
