How to Fix a Loose Cabinet Knob
    1. How to Fix a Loose Cabinet Knob, How to Fix a Loose Cabinet Knob: step 1, image 1 of 3 How to Fix a Loose Cabinet Knob, How to Fix a Loose Cabinet Knob: step 1, image 2 of 3 How to Fix a Loose Cabinet Knob, How to Fix a Loose Cabinet Knob: step 1, image 3 of 3
      • Remove the drawer from the cabinet/dresser.
      • Do this so you have enough room to work with.
      Ask FixBot
    2. How to Fix a Loose Cabinet Knob: step 2, image 1 of 3 How to Fix a Loose Cabinet Knob: step 2, image 2 of 3 How to Fix a Loose Cabinet Knob: step 2, image 3 of 3
      • Take your screw driver to remove the screw from the knob.
      • Place the screwdriver on the screw turning the screwdriver counter clock wise to untighten the screw from the knob.
      • Knowing that every cabinet and drawers are different will determine how many screws you will need to untighten for this repair.
      Ask FixBot
    3. How to Fix a Loose Cabinet Knob: step 3, image 1 of 3 How to Fix a Loose Cabinet Knob: step 3, image 2 of 3 How to Fix a Loose Cabinet Knob: step 3, image 3 of 3
      • Next, you will then remove the screw from the desired hole.
      Ask FixBot
    4. How to Fix a Loose Cabinet Knob: step 4, image 1 of 2 How to Fix a Loose Cabinet Knob: step 4, image 2 of 2
      • Inspect the threading of the screw to see whether the screw is still in good condition or if there is any jagged threading on the body portion of the screw.
      • If your screw does not appear to be in good condition, then you would have to purchase another screw. Remember to take the knob with you to the store so that you can get the correct screw for that knob.
      Ask FixBot
    5. How to Fix a Loose Cabinet Knob: step 5, image 1 of 3 How to Fix a Loose Cabinet Knob: step 5, image 2 of 3 How to Fix a Loose Cabinet Knob: step 5, image 3 of 3
      • Inspect the holes within the knob and drawer.
      • You would perform this step to see if there is any extra debris that was left behind.
      Ask FixBot
    6. How to Fix a Loose Cabinet Knob: step 6, image 1 of 2 How to Fix a Loose Cabinet Knob: step 6, image 2 of 2
      • Place washers on the screw.
      Ask FixBot
    7. How to Fix a Loose Cabinet Knob: step 7, image 1 of 3 How to Fix a Loose Cabinet Knob: step 7, image 2 of 3 How to Fix a Loose Cabinet Knob: step 7, image 3 of 3
      • Insert the screw in the desired hole.
      Ask FixBot
    8. How to Fix a Loose Cabinet Knob: step 8, image 1 of 2 How to Fix a Loose Cabinet Knob: step 8, image 2 of 2
      • Place the knob in front of the cabinet/drawer where the screw would be in place.
      Ask FixBot
    9. How to Fix a Loose Cabinet Knob: step 9, image 1 of 3 How to Fix a Loose Cabinet Knob: step 9, image 2 of 3 How to Fix a Loose Cabinet Knob: step 9, image 3 of 3
      • Hand tighten the screw on the knob.
      • Since you are holding the screw with your left hand and the knob with your right all you have to do is turn the screw clockwise, so the knob can tighten on the screw.
      • Make sure to hold the knob in place while performing this step.
      Ask FixBot
    10. How to Fix a Loose Cabinet Knob: step 10, image 1 of 3 How to Fix a Loose Cabinet Knob: step 10, image 2 of 3 How to Fix a Loose Cabinet Knob: step 10, image 3 of 3
      • Use your screwdriver to finish tightening the screw in place.
      • Remember to keep the knob in place while completing this step.
      Ask FixBot
    11. How to Fix a Loose Cabinet Knob: step 11, image 1 of 2 How to Fix a Loose Cabinet Knob: step 11, image 2 of 2
      • Check to see if the knob is tight and secure.
      Ask FixBot
    12. How to Fix a Loose Cabinet Knob: step 12, image 1 of 3 How to Fix a Loose Cabinet Knob: step 12, image 2 of 3 How to Fix a Loose Cabinet Knob: step 12, image 3 of 3
      • Place the drawer back in the cabinet/dresser.
      • Congratulations! You fixed your loose cabinet knob.
      Ask FixBot
Sandra William
241 Reputation
1 Guide authored
2 Guide Comments
Thanks Sandra. Appreciate all the photos as I really don’t know how to do many home repairs.
W. B. - Reply Share
Another aspect of iFixit,
Home repair
Kind-hearted, spirited Man - Reply Share
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 77
All Time: 4,977
