How to Fix a Leaning Wooden Gate
  1. How to Fix a Leaning Wooden Gate, How to Fix a Leaning Wooden Gate: step 1, image 1 of 2 How to Fix a Leaning Wooden Gate, How to Fix a Leaning Wooden Gate: step 1, image 2 of 2
    • Begin by measuring the gap under the gate to determine the exact height needed for correction.
    Ask FixBot
  2. How to Fix a Leaning Wooden Gate: step 2, image 1 of 1
    • Choose any object that is the same size as the measured gap.
    • Place the selected object under the gate to ensure the gate is level and straight.
    Ask FixBot
  3. How to Fix a Leaning Wooden Gate: step 3, image 1 of 3 How to Fix a Leaning Wooden Gate: step 3, image 2 of 3 How to Fix a Leaning Wooden Gate: step 3, image 3 of 3
    • Place the wheel on the side where the door is leaning down.
    • Mark the hole location for drilling.
    • Use masking tape only if the door is the same colour as your marking object.
    Ask FixBot
  4. How to Fix a Leaning Wooden Gate: step 4, image 1 of 3 How to Fix a Leaning Wooden Gate: step 4, image 2 of 3 How to Fix a Leaning Wooden Gate: step 4, image 3 of 3
    • Drill holes on the marked circles.
    • Ensure your holes are the same size as the screw you are using.
    Ask FixBot
  5. How to Fix a Leaning Wooden Gate: step 5, image 1 of 2 How to Fix a Leaning Wooden Gate: step 5, image 2 of 2
    • Attach the wheel and place the screws .
    • Depending on what the kit provides, use a wrench to tighten the bolts or a screwdriver to tighten the screws.
    • Ensure that the screw is tightened securely to prevent a loose wheel.
    Ask FixBot
  6. How to Fix a Leaning Wooden Gate: step 6, image 1 of 2 How to Fix a Leaning Wooden Gate: step 6, image 2 of 2
    • Remove the object you placed underneath.
    Ask FixBot
Test out your newly added wheels, if it is wobbly make sure to tighten the wheels again.
TenzinY
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 44
All Time: 766
