Introduction
Go to step 1 ↓Water is leaking at the connection between the shower head and the pipe? No problem! Here are some simple steps to fix it!
Parts
Tools
Use a ruler to measure about 8" long on the teflon tape. Then use a pair of scissors to cut it.
The tape is replaced! However this may not have solved your problem. If the showerhead still leaks from the joint with the shower arm, there may be dirt or debris in the joint, or damaged threads on the shower arm.
Try tightening the showerhead a little more with your wrench, or reapplying teflon tape to ensure a good layer.
This guide is made to maintain the tightened connection between the shower head and the pipe. If the shower head is leaking water elsewhere except at the connection, please seek for other fixing guides for repairing shower head leaking problem.
6 other people completed this guide.
1 Guide Comment
I found the rubber washer was missing on the end of the hose so I put a 1/4" rubber grommet and it just happened to squish in the middle for a leak-less connection.
