How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock
  1. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock, How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: step 1, image 1 of 2 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock, How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: step 1, image 2 of 2
    • Make sure the lock is in the unlock position when you start.
    • Use a Philips #1 screwdriver to remove the two 8 mm screws from the left and right sides of the lock.
    Ask FixBot
  2. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: step 2, image 1 of 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: step 2, image 2 of 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: step 2, image 3 of 3
    • Lift the faceplate from the lock.
    • Locate the battery pack stationed at the top of the lock and the programming button at the center of the lock.
    Ask FixBot
  3. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: step 3, image 1 of 1
    • Pull the battery pack up and off to remove it from the lock housing.
    Ask FixBot
  4. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: step 4, image 1 of 2 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: step 4, image 2 of 2
    • Re-insert the battery pack while holding down the programming button.
    • Ensure the battery pack is fully inserted by pushing it down.
    Ask FixBot
  5. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: step 5, image 1 of 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: step 5, image 2 of 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: step 5, image 3 of 3
    • Release the programming button after the indicator light turns red then green.
    • Repeat steps 3 through 5 if the light does not turn green.
    Ask FixBot
  6. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: step 6, image 1 of 2 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: step 6, image 2 of 2
    • Press the program button again to allow the Smartlock to re-calibrate and reprogram itself.
    • The lock will lock and unlock a few times to calibrate and will remain in the lock position when the calibration is complete.
    Ask FixBot
  7. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: step 7, image 1 of 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: step 7, image 2 of 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: step 7, image 3 of 3
    • To reassemble your lock, reseat the faceplate on the lock.
    • Twist the lock switch until it aligns with the bolt mechanism and the faceplate sits flush against the lock.
    • Use the Phillips #1 screwdriver to secure the two 8 mm screws back into place to conclude the fix.
    Ask FixBot
Your lock will not jam anymore!
2 other people completed this guide.
Manpreet Sahota
172 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 165
All Time: 19,807
