Up to 20% off select tools
How to Fix a Jammed Needle
Views: 1.4K
View statistics:
Past 24 Hours:
11
Past 7 Days:
61
Past 30 Days:
238
All Time:
1,407
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
The aim of this guide is to address a common issue: when the needle gets stuck in the fabric while sewing. This problem occurs more frequently than one might expect, particularly when working with thin fabrics that challenge the needle’s strength. This guide offers step-by-step instructions to help you address and resolve this issue, specifically for your Janome 3160QDC sewing machine.
    1. How to Fix a Jammed Needle, How to Fix a Jammed Needle: step 1, image 1 of 3 How to Fix a Jammed Needle, How to Fix a Jammed Needle: step 1, image 2 of 3 How to Fix a Jammed Needle, How to Fix a Jammed Needle: step 1, image 3 of 3
      • If the needle gets stuck while sewing a stitch, stop sewing.
      • Turn the knob on the side of your machine to manually lift the needle out of the fabric.
      Ask FixBot
    2. How to Fix a Jammed Needle: step 2, image 1 of 3 How to Fix a Jammed Needle: step 2, image 2 of 3 How to Fix a Jammed Needle: step 2, image 3 of 3
      • Once the needle is out of the fabric, use the block level to lift the plastic foot press from the fabric.
      Ask FixBot
    3. How to Fix a Jammed Needle: step 3, image 1 of 2 How to Fix a Jammed Needle: step 3, image 2 of 2
      • Once the plastic foot press is lifted from the fabric, pull the fabric away from the machine and cut the thread.
      Ask FixBot
    4. How to Fix a Jammed Needle: step 4, image 1 of 3 How to Fix a Jammed Needle: step 4, image 2 of 3 How to Fix a Jammed Needle: step 4, image 3 of 3
      • Open the bobbin holder and remove the bobbin. Also remove the thread from the machine.
      Ask FixBot
    5. How to Fix a Jammed Needle: step 5, image 1 of 3 How to Fix a Jammed Needle: step 5, image 2 of 3 How to Fix a Jammed Needle: step 5, image 3 of 3
      • Using the metal knob on the right side of the needle, unscrew and remove the needle. Once the needle has been removed, inspect it for damages. If there is no damage, reinsert the same needle. If there are damages, replace the needle.
      Ask FixBot
    6. How to Fix a Jammed Needle: step 6, image 1 of 2 How to Fix a Jammed Needle: step 6, image 2 of 2
      • Once the needle is back in the sewing machine, thread both the needle and the bobbin. From here, you are able to begin sewing again.
      Ask FixBot
Author
with
Abby Karin Palko
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 61
Past 30 Days: 238
All Time: 1,407
