How to Fix a Jammed Mahjong Table
Views: 3.3K
View statistics:
Past 24 Hours:
9
Past 7 Days:
61
Past 30 Days:
297
All Time:
3,326
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
This guide addresses the issue of a foreign object falling into the opening beneath the mahjong table control panel, causing one or more of the four long tile platforms to be jammed. This results in the mahjong table tiles not rising from underneath the board properly. Often, when any of the four platforms opens up to create the tile "wall," small objects such as the scorekeeping chips may accidentally fall into the mechanism, rendering the machine unplayable. Below are the steps to fix the problem. These steps work for any kind of automatic mahjong table.
Tools
    1. How to Fix a Jammed Mahjong Table, How to Fix a Jammed Mahjong Table: step 1, image 1 of 1
      • Unplug the mahjong table.
      Ask FixBot
    2. How to Fix a Jammed Mahjong Table: step 2, image 1 of 1
      • Remove the outer edge of the mahjong table and set it aside.
      Ask FixBot
    3. How to Fix a Jammed Mahjong Table: step 3, image 1 of 2 How to Fix a Jammed Mahjong Table: step 3, image 2 of 2
      • Lift the top frame up, exposing the inside.
      Ask FixBot
    4. How to Fix a Jammed Mahjong Table: step 4, image 1 of 3 How to Fix a Jammed Mahjong Table: step 4, image 2 of 3 How to Fix a Jammed Mahjong Table: step 4, image 3 of 3
      • Be cautious when putting your hands inside due to sharp parts: gloves and tweezer recommended.
      • Remove the long (green) platform cover of the jammed platform and set it aside to expose the opening of the platform.
      • Carefully remove the foreign object from the opening of the platform.
      Ask FixBot
    5. How to Fix a Jammed Mahjong Table: step 5, image 1 of 1
      • After removing the foreign object, remove the rest of the tiles and set them aside.
      Ask FixBot
    6. How to Fix a Jammed Mahjong Table: step 6, image 1 of 2 How to Fix a Jammed Mahjong Table: step 6, image 2 of 2
      • Reassemble all the components and turn on the power.
      Ask FixBot
    7. How to Fix a Jammed Mahjong Table: step 7, image 1 of 1
      • Press the center control panel to expose the center hole.
      • Push all the tiles in the center hole to ensure the machine properly builds the "wall" for play.
      Ask FixBot
Finish Line
2 other people completed this guide.
ShuRen
175 Reputation
1 Guide authored
UC Davis, Team 1-4, Whithaus Spring 2024 Member of UC Davis, Team 1-4, Whithaus Spring 2024
UCD-WHITHAUS-S24S1G4
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 61
Past 30 Days: 297
All Time: 3,326
