How to Fix a Jammed Key on a Logitech K120
  1. How to Fix a Jammed Key on a Logitech K120, How to Fix a Jammed Key on a Logitech K120: step 1, image 1 of 2 How to Fix a Jammed Key on a Logitech K120, How to Fix a Jammed Key on a Logitech K120: step 1, image 2 of 2
    • Unplug the keyboard to prevent accidental damage.
    Ask FixBot
  2. How to Fix a Jammed Key on a Logitech K120: step 2, image 1 of 3 How to Fix a Jammed Key on a Logitech K120: step 2, image 2 of 3 How to Fix a Jammed Key on a Logitech K120: step 2, image 3 of 3
    • Gently remove the keycap using a keycap puller/screwdriver/nylon spudger, or a plastic opening tool. Inspect for dirt, dust, or misalignment.
    • Avoid using excessive force to prevent damage.
    Ask FixBot
  3. How to Fix a Jammed Key on a Logitech K120: step 3, image 1 of 1
    • Clean the area under the key using compressed air, a microfiber cloth, or a cotton swab for detailed cleaning.
    Ask FixBot
  4. How to Fix a Jammed Key on a Logitech K120: step 4, image 1 of 3 How to Fix a Jammed Key on a Logitech K120: step 4, image 2 of 3 How to Fix a Jammed Key on a Logitech K120: step 4, image 3 of 3
    • Examine the stabilizer and ensure it is properly attached.
    Ask FixBot
  5. How to Fix a Jammed Key on a Logitech K120: step 5, image 1 of 1
    • Test the switch by pressing it without the keycap (you can press it with a cotton swab).
    Ask FixBot
  6. How to Fix a Jammed Key on a Logitech K120: step 6, image 1 of 2 How to Fix a Jammed Key on a Logitech K120: step 6, image 2 of 2
    • Reattach the keycap by aligning it properly and pressing it down firmly but gently to avoid damaging the switch.
    Ask FixBot
  7. How to Fix a Jammed Key on a Logitech K120: step 7, image 1 of 2 How to Fix a Jammed Key on a Logitech K120: step 7, image 2 of 2
    • Test the key’s functionality by typing in a text editor or keyboard tester to ensure proper response. If the issue persists, repeat cleaning steps.
    Ask FixBot
Finish Line
RepairWithAI
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 79
All Time: 729
