How to Fix a Hole In Wall
  1. How to Fix a Hole In Wall, Dry wall: step 1, image 1 of 3 How to Fix a Hole In Wall, Dry wall: step 1, image 2 of 3 How to Fix a Hole In Wall, Dry wall: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Use pliers (or tweezers if the hole is very small) to clean out hole by removing the drywall out of the hole.
  2. How to Fix a Hole In Wall: step 2, image 1 of 1
    • Use scissors to cut drywall mesh.
    • To ensure that the entire hole is covered, cut a piece of mesh larger than the size of the hole.
  3. How to Fix a Hole In Wall: step 3, image 1 of 2 How to Fix a Hole In Wall: step 3, image 2 of 2
    • Use a damp sponge to apply moisture to make the mesh stick to the wall, covering the entire hole.
  4. How to Fix a Hole In Wall: step 4, image 1 of 3 How to Fix a Hole In Wall: step 4, image 2 of 3 How to Fix a Hole In Wall: step 4, image 3 of 3
    • Use a drywall knife to apply the drywall compound over the mesh. Make sure to spread a generous amount over the entire mesh.
    • Let the compound dry for about 30 minutes.
    • You can speed up the drying process by placing a fan directly in front of the drying compound.
  5. How to Fix a Hole In Wall: step 5, image 1 of 1
    • Once compound is dry, use sandpaper to smooth out the entire surface of the dried compound.
  6. How to Fix a Hole In Wall: step 6, image 1 of 3 How to Fix a Hole In Wall: step 6, image 2 of 3 How to Fix a Hole In Wall: step 6, image 3 of 3
    • Paint over the surface with a paint brush.
    • Use paint that matches the rest of the wall for best results.
8 other people completed this guide.
1 Guide Comment
Oi! como faço reboca que a parede está pintada branca?
dezinho anderson - Reply Share
Past 24 Hours: 12
Past 7 Days: 77
Past 30 Days: 264
All Time: 9,373
