How to Fix a Flat Soccer Ball
  1. How to Fix a Flat Soccer Ball, How to Fix a Flat Soccer Ball: step 1, image 1 of 2 How to Fix a Flat Soccer Ball, How to Fix a Flat Soccer Ball: step 1, image 2 of 2
    • Attach the needle to the syringe.
    • Inserting & using a needle can cause a puncture injury. Please handle with care.
    Ask FixBot
  2. How to Fix a Flat Soccer Ball: step 2, image 1 of 2 How to Fix a Flat Soccer Ball: step 2, image 2 of 2
    • Insert the needle into the butyl valve of the ball.
    Ask FixBot
  3. How to Fix a Flat Soccer Ball: step 3, image 1 of 3 How to Fix a Flat Soccer Ball: step 3, image 2 of 3 How to Fix a Flat Soccer Ball: step 3, image 3 of 3
    • Rotate the ball so the syringe is facing upwards.
    • Fill the syringe with 20 - 30 ml of tire sealant.
    • Avoid direct contact with tire sealant; it can irritate eyes and skin, and is hazardous if swallowed.
    Ask FixBot
  4. How to Fix a Flat Soccer Ball: step 4, image 1 of 2 How to Fix a Flat Soccer Ball: step 4, image 2 of 2
    • Push the plunger until the syringe is empty.
    • Remove the syringe.
    Ask FixBot
  5. How to Fix a Flat Soccer Ball: step 5, image 1 of 2 How to Fix a Flat Soccer Ball: step 5, image 2 of 2
    • Shake and roll the ball for 3 minutes, allowing the sealant to coat the inside.
    Ask FixBot
  6. How to Fix a Flat Soccer Ball: step 6, image 1 of 1
    • Wait 20 minutes for the sealant to dry.
    Ask FixBot
  7. How to Fix a Flat Soccer Ball: step 7, image 1 of 1
    • Now it's ready to pump up and play!
    Ask FixBot
Finish Line
Meloddy Robles Mora
145 Reputation
1 Guide authored
UC Davis, Team 4-8, Whithaus Spring 2024 Member of UC Davis, Team 4-8, Whithaus Spring 2024
UCD-WHITHAUS-S24S4G8
4 Members
1 Guide authored
1 Guide Comment
Do u have an issue with the slime glue clogging
Andy Ni - Reply Share
Past 24 Hours: 13
Past 7 Days: 89
Past 30 Days: 545
All Time: 5,104
