How to Fix a Faulty Button on a Mayflash F300
  1. How to Fix a Faulty Button on a Mayflash F300, How to Fix a Faulty Button on a Mayflash F300: step 1, image 1 of 2 How to Fix a Faulty Button on a Mayflash F300, How to Fix a Faulty Button on a Mayflash F300: step 1, image 2 of 2
    • Flip around the Mayflash F300, so that the metal panel is facing you.
    • It may be helpful to place the device on a box if you cannot hold it, as the joystick would otherwise be under pressure.
  2. How to Fix a Faulty Button on a Mayflash F300: step 2, image 1 of 3 How to Fix a Faulty Button on a Mayflash F300: step 2, image 2 of 3 How to Fix a Faulty Button on a Mayflash F300: step 2, image 3 of 3
    • Unscrew the six 9 mm Phillips #00 screws that hold together the metal panel.
    • Gently pry the panel away once it is unscrewed.
  3. How to Fix a Faulty Button on a Mayflash F300: step 3, image 1 of 2 How to Fix a Faulty Button on a Mayflash F300: step 3, image 2 of 2
    • Unplug the two cables going into the button you wish to clean or replace.
    • These two cables can be quite stubborn to remove, so gently wiggling them as you pull will make it easier.
  4. How to Fix a Faulty Button on a Mayflash F300: step 4, image 1 of 1
    • Squeeze the two tabs that are on either side of the button and push it out.
  5. How to Fix a Faulty Button on a Mayflash F300: step 5, image 1 of 1
    • Grab your toothbrush and clean out all the dirt you may find inside and around the button.
    • Alternatively, if you wish to install an entirely new button, you can simply set aside the old one.
  6. How to Fix a Faulty Button on a Mayflash F300: step 6, image 1 of 2 How to Fix a Faulty Button on a Mayflash F300: step 6, image 2 of 2
    • With your button now clean and ready to go, place it in the empty slot and push it back down. Make sure it snaps in place.
  7. How to Fix a Faulty Button on a Mayflash F300: step 7, image 1 of 1
    • Reconnect the two cables to the button.
  8. How to Fix a Faulty Button on a Mayflash F300: step 8, image 1 of 1
    • Take the back panel of the arcade stick and screw it back in place.
Hopefully these steps were clear and useful to you! Happy gaming!
Ali Fareed
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 68
All Time: 933
