How to Fix a Dry Printer Cartridge
Views: 66K
View statistics:
Past 24 Hours:
14
Past 7 Days:
126
Past 30 Days:
737
All Time:
65,917
Comments: 12
4 comments on steps, 8 guide comments.
Go to guide comments
Completed: 18
18 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Not using a printer for a long period of time can cause the ink inside it to dry. When we can’t use the dried ink cartridge, most of us get rid of it and buy a new cartridge, which contributes to the increasing e-waste. Instead of discarding a dry cartridge, this guide will help you to fix it in a few easy steps with a couple of things needed which can be found right in your house.
    1. How to Fix a Dry Printer Cartridge, Removing the Cartridge: step 1, image 1 of 3 How to Fix a Dry Printer Cartridge, Removing the Cartridge: step 1, image 2 of 3 How to Fix a Dry Printer Cartridge, Removing the Cartridge: step 1, image 3 of 3
      • Open the top case of your printer.
      • Carefully remove the dried cartridge by lifting the flap in the bottom right section of the printer.
      Ask FixBot
    2. How to Fix a Dry Printer Cartridge, Applying Hand Sanitizer: step 2, image 1 of 2 How to Fix a Dry Printer Cartridge, Applying Hand Sanitizer: step 2, image 2 of 2
      • Place the cartridge on a clean surface and apply a few drops of alcohol-based hand sanitizer to the ink nozzle.
      • It's best to use an unscented hand sanitizer, as some scents or colors in the hand sanitizer may affect your ink cartridge's performance.
      • Gently rub your finger on the ink nozzle once or twice.
      • Let the sanitizer seep in for a few minutes.
      • While you wait, fill a bowl halfway with warm tap water.
      Ask FixBot
    3. How to Fix a Dry Printer Cartridge, Wipe it out: step 3, image 1 of 2 How to Fix a Dry Printer Cartridge, Wipe it out: step 3, image 2 of 2
      • Wipe out the ink nozzle where you applied the sanitizer with a clean cloth or paper towel.
      Ask FixBot
    4. How to Fix a Dry Printer Cartridge, Warm Water Bath: step 4, image 1 of 3 How to Fix a Dry Printer Cartridge, Warm Water Bath: step 4, image 2 of 3 How to Fix a Dry Printer Cartridge, Warm Water Bath: step 4, image 3 of 3
      • Place the nozzle side of the cartridge into a bowl filled with warm water.
      • Do not completely submerge the cartridge inside the water, just half of it.
      • Wait for 5-10 mins or until you see ink leaking out into the water.
      • Once you see ink leaking out, remove the cartridge from the water carefully.
      • It may be a good idea to keep a bit of paper towel or a rag handy to catch any drips from the ink cart.
      Ask FixBot
    5. How to Fix a Dry Printer Cartridge, Dry it Completely: step 5, image 1 of 1
      • After removing it from the water, completely clean the cartridge with a soft cloth or a paper towel and dry it out.
      • DO NOT put a wet cartridge inside the printer, else it can damage it.
      Ask FixBot
    6. How to Fix a Dry Printer Cartridge, Double Check: step 6, image 1 of 1
      • To make sure the cartridge is fully working now, take a piece of paper and rub the ink nozzle over it.
      • When you see an ink line on the paper, that means you are good to go.
      Ask FixBot
    7. How to Fix a Dry Printer Cartridge, Fixing it Back: step 7, image 1 of 1
      • Once the body of the cartridge has completely dried, place it back into the slot in the printer.
      Ask FixBot
18 other people completed this guide.
Hariom Godhani
622 Reputation
1 Guide authored
8 Guide Comments
Thank you. This worked for me.
Thomas Grace - Reply Share
Thank you 👍
Suzan Duran - Reply Share
This actually worked . Did just as you instructed , didn't see ink in the hot water but after a few minutes I dried the cartridges off and had ink on the paper towel . Worked great ,Thanks Hariom .
Tim - Reply Share
Tried this with HP 60 black and tri-colour cartridges, which were both brand new, sealed cartridges, but were probably sitting in the box since ~2008. It did manage to loosen the ink up enough that if I ran the nozzle along a damp coffee filter, it would leave a solid black line, or in the case of the colour cartridge, a line of 3 stripes: cyan, yellow, then magenta. Unfortunately, the moment I dry them off and pop them back in the printer, nothing happens. I did manage to get the faded mostly cyan top third of a test page once, but that was it. Repeated the process more thoroughly, and got a more consistent output of ink on the filter, but the result after that was nothing but blank sheets.
Not really sure what to do beyond this, because I could probably just pick up a new printer for the price of these cartridges. This would probably work well for newer cartridges that were printing fine, but then were just left idle for a few months too long between prints.
Jordan “gordo” Zanatta - Reply Share
At least you tried it and you know what to do if the cartridges aren't left for a lessor time.
DEAN - Reply Share
Past 24 Hours: 14
Past 7 Days: 126
Past 30 Days: 737
All Time: 65,917
