How to Fix a Damaged VHS Tape
  1. How to Fix a Damaged VHS Tape, How to Fix a Damaged VHS Tape: step 1, image 1 of 3 How to Fix a Damaged VHS Tape, How to Fix a Damaged VHS Tape: step 1, image 2 of 3 How to Fix a Damaged VHS Tape, How to Fix a Damaged VHS Tape: step 1, image 3 of 3
    • Remove the screws at the bottom of the VHS case using a Phillips #0 screwdriver.
    Ask FixBot
  2. How to Fix a Damaged VHS Tape: step 2, image 1 of 2 How to Fix a Damaged VHS Tape: step 2, image 2 of 2
    • Lift open the cover of the VHS.
    Ask FixBot
  3. How to Fix a Damaged VHS Tape: step 3, image 1 of 2 How to Fix a Damaged VHS Tape: step 3, image 2 of 2
    • Remove the top cover of the VHS case.
    Ask FixBot
  4. How to Fix a Damaged VHS Tape: step 4, image 1 of 3 How to Fix a Damaged VHS Tape: step 4, image 2 of 3 How to Fix a Damaged VHS Tape: step 4, image 3 of 3
    • Replace any rollers that accidently fall out of the VHS case.
    Ask FixBot
  5. How to Fix a Damaged VHS Tape: step 5, image 1 of 3 How to Fix a Damaged VHS Tape: step 5, image 2 of 3 How to Fix a Damaged VHS Tape: step 5, image 3 of 3
    • Unroll the video tape from each side of the VHS, running it through the rollers the correct way. Do this until you reach the damaged parts of the tape.
    Ask FixBot
  6. How to Fix a Damaged VHS Tape: step 6, image 1 of 3 How to Fix a Damaged VHS Tape: step 6, image 2 of 3 How to Fix a Damaged VHS Tape: step 6, image 3 of 3
    • Cut out the wrinkled and damaged parts of the VHS tape using scissors.
    Ask FixBot
  7. How to Fix a Damaged VHS Tape: step 7, image 1 of 1
    • Hold the undamaged parts of the tape over each other as evenly as possible.
    Ask FixBot
  8. How to Fix a Damaged VHS Tape: step 8, image 1 of 2 How to Fix a Damaged VHS Tape: step 8, image 2 of 2
    • Cut the overlapping portion of the tape at an angle.
    Ask FixBot
  9. How to Fix a Damaged VHS Tape: step 9, image 1 of 2 How to Fix a Damaged VHS Tape: step 9, image 2 of 2
    • Apply scotch tape to the dull side of the two matching halves of the VHS tape.
    • Potential for device damage: Do not wrap the scotch tape around the other side of the VHS tape.
    Ask FixBot
  10. How to Fix a Damaged VHS Tape: step 10, image 1 of 3 How to Fix a Damaged VHS Tape: step 10, image 2 of 3 How to Fix a Damaged VHS Tape: step 10, image 3 of 3
    • Cut excess scotch tape to match the size of the VHS tape as precisely as possible.
    Ask FixBot
  11. How to Fix a Damaged VHS Tape: step 11, image 1 of 3 How to Fix a Damaged VHS Tape: step 11, image 2 of 3 How to Fix a Damaged VHS Tape: step 11, image 3 of 3
    • Wind the loose VHS tape back into the case.
    Ask FixBot
  12. How to Fix a Damaged VHS Tape: step 12, image 1 of 3 How to Fix a Damaged VHS Tape: step 12, image 2 of 3 How to Fix a Damaged VHS Tape: step 12, image 3 of 3
    • Replace the cover back on top of the VHS case.
    Ask FixBot
  13. How to Fix a Damaged VHS Tape: step 13, image 1 of 3 How to Fix a Damaged VHS Tape: step 13, image 2 of 3 How to Fix a Damaged VHS Tape: step 13, image 3 of 3
    • Reinsert the screws through the bottom of the VHS tape.
    Ask FixBot
Finish Line
2 other people completed this guide.
Nicholas Monroe
265 Reputation
1 Guide authored
4 Guide Comments
Na het monteren van de tape, en voor het sluiten van de cassette hield ik nog een klein zwart onderdeeltje over en kan het niet meer herplaatsen, deel omdat de behuizing nagenoeg zwart is, en ook omdat ik niets wil forceren. Zou een tip om de plaats van dit onderdeel te vinden enorm op prijs stellen.
Jan - Reply Share
Inmiddels van iemand een VHS band geleend, opengemaakt en vastgesteld waar het blokje past, bij de afbeelding 4 en 5 is dat helaas slecht te zien, maar het blokje past in een kleine ruimte tussen de twee spoelen. Het zou mooi zijn, als je plaatjes kon toevoegen, maar goed probleem opgelost, en nu opnieuw met de videograbber aan de slag, wat leveren de Kabelshop en NEDIS een slecht service, door steeds verwijzen dat het aan de kabel ligt, de videospeler, of de aansluiting met de Windows PC, feitelijk stijllloos.
Jan - Reply Share
domz - Reply Share
I'm unsure which side is the dull or shiny side in step 9, they both look shiny to me. Maybe clarify whether the tape is on the inside or outside of the loop?
journaljemmy - Reply Share
Past 24 Hours: 3
Past 7 Days: 42
Past 30 Days: 218
All Time: 13,694
