How to Fix a Bubble Wand Button
View statistics:
Past 24 Hours:
7
Past 7 Days:
38
Past 30 Days:
176
All Time:
679
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide shows how to disassemble the plastic outer casing of a battery-operated bubble wand to access the button mechanism, battery contacts, and internal wiring. Opening the housing allows you to clean debris, fix a stuck button, and troubleshoot power issues if the bubble wand stops working properly.
Before beginning, remove the batteries and work on a dry, flat surface to avoid damage to the internal components.
Tools
    1. How to Fix a Bubble Wand Button, How to Fix a Bubble Wand Button: step 1, image 1 of 3 How to Fix a Bubble Wand Button, How to Fix a Bubble Wand Button: step 1, image 2 of 3 How to Fix a Bubble Wand Button, How to Fix a Bubble Wand Button: step 1, image 3 of 3
      • Open the battery compartment and remove the batteries from the bubble wand.
      • Set the batteries aside in a safe place.
      • Do not work on the toy while batteries are still installed.
      Ask FixBot
    2. How to Fix a Bubble Wand Button: step 2, image 1 of 3 How to Fix a Bubble Wand Button: step 2, image 2 of 3 How to Fix a Bubble Wand Button: step 2, image 3 of 3
      • Remove the screws securing the plastic outer casing with a small Phillips screwdriver.
      • Place the screws somewhere safe so they are not lost.
      Ask FixBot
    3. How to Fix a Bubble Wand Button: step 3, image 1 of 1
      • Carefully separate the two halves of the plastic casing.
      • Open the casing slowly to avoid damaging the internal clips or wires.
      Ask FixBot
    4. How to Fix a Bubble Wand Button: step 4, image 1 of 3 How to Fix a Bubble Wand Button: step 4, image 2 of 3 How to Fix a Bubble Wand Button: step 4, image 3 of 3
      • Inspect the button mechanism and cap for dried bubble solution, dirt, or sticky residue.
      • Clean away any buildup preventing the button from moving freely.
      Ask FixBot
    5. How to Fix a Bubble Wand Button: step 5, image 1 of 3 How to Fix a Bubble Wand Button: step 5, image 2 of 3 How to Fix a Bubble Wand Button: step 5, image 3 of 3
      • Use a cotton swab with warm water to clean around the button cap.
      • Remove stuck debris with a toothpick or tweezers if needed.
      • Dry the area completely before reassembly.
      • Avoid getting water near the motor or battery contacts.
      Ask FixBot
    6. How to Fix a Bubble Wand Button: step 6, image 1 of 3 How to Fix a Bubble Wand Button: step 6, image 2 of 3 How to Fix a Bubble Wand Button: step 6, image 3 of 3
      • Align both halves of the plastic casing.
      • Carefully close the housing without pinching any wires.
      • Reinstall all screws securely.
      Ask FixBot
    7. How to Fix a Bubble Wand Button: step 7, image 1 of 3 How to Fix a Bubble Wand Button: step 7, image 2 of 3 How to Fix a Bubble Wand Button: step 7, image 3 of 3
      • Reinsert the batteries into the battery compartment.
      • Press the button to confirm the bubble wand powers on properly.
      Ask FixBot
Finish Line
Corrin
158 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 38
Past 30 Days: 176
All Time: 679
