How to Fix a Broken XLR Microphone Cable
  1. How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: step 1, image 1 of 3 How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: step 1, image 2 of 3 How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: step 1, image 3 of 3
    • This guide will utilize a soldering iron. Please use a heat-resistant surface and proceed with caution.
    • Place the end of the XLR Cable on a clean, uncluttered surface.
    • Using a small screwdriver, unscrew the single screw near the top of the cable.
    • Gently pull apart the exterior metal from the internal mechanism.
    Ask FixBot
  2. How to Fix a Broken XLR Microphone Cable: step 2, image 1 of 1
    • Assess which connections have fallen loose. In this instance, the white cable is disconnected.
    Ask FixBot
  3. How to Fix a Broken XLR Microphone Cable: step 3, image 1 of 2 How to Fix a Broken XLR Microphone Cable: step 3, image 2 of 2
    • Assess whether or not there's enough exposed wire to reconnect loose cables. In this instance, the exposed cables are too short to effectively reconnect.
    • If the exposed wires are too short, use wire strippers or a razor to cut back the insulation.
    • Separate the wires.
    Ask FixBot
  4. How to Fix a Broken XLR Microphone Cable: step 4, image 1 of 3 How to Fix a Broken XLR Microphone Cable: step 4, image 2 of 3 How to Fix a Broken XLR Microphone Cable: step 4, image 3 of 3
    • Soldering irons are extremely hot. Proceed with extreme caution.
    • Solder each of the loose wires to the coinciding metal prong.
    • For more information on effectively soldering wire, please visit iFixit's Soldering Guide.
    • If necessary, use a thin wire to further manipulate the connection.
    Ask FixBot
  5. How to Fix a Broken XLR Microphone Cable: step 5, image 1 of 2 How to Fix a Broken XLR Microphone Cable: step 5, image 2 of 2
    • When the soldering is complete, reconnect the metal exterior to the head of the cable.
    • Using a small screwdriver, reattach the single screw.
    Ask FixBot
4 other people completed this guide.
Abbie Zajac
203 Reputation
1 Guide authored
1 Guide Comment
Great repair. If the cabke is broken I have a video on resolving that issue. https://youtu.be/E8CiX4cnc-U
DIM Tips - Reply Share
Past 24 Hours: 13
Past 7 Days: 43
Past 30 Days: 185
All Time: 28,193
