How to Fix a Broken Plastic Figurine
    1. How to Fix a Broken Plastic Figurine, How to Fix a Broken Plastic Figurine: step 1, image 1 of 2 How to Fix a Broken Plastic Figurine, How to Fix a Broken Plastic Figurine: step 1, image 2 of 2
      • Wipe down the figurine carefully with an alcohol wipe, focusing on the broken areas.
      Ask FixBot
    2. How to Fix a Broken Plastic Figurine: step 2, image 1 of 3 How to Fix a Broken Plastic Figurine: step 2, image 2 of 3 How to Fix a Broken Plastic Figurine: step 2, image 3 of 3
      • Plug in the hot glue gun and let it heat up.
      • Do not directly touch the tip of the hot glue gun.
      • Straighten out the paperclip.
      • Place the paperclip in the tip of the hot glue gun in order to heat the metal.
      • Allow the paperclip to heat up for 5 minutes.
      Ask FixBot
    3. How to Fix a Broken Plastic Figurine: step 3, image 1 of 1
      • Remove the paperclip from the glue gun.
      • Use the heated paperclip to scrape away excess material from one part of the figurine.
      Ask FixBot
    4. How to Fix a Broken Plastic Figurine: step 4, image 1 of 1
      • Firmly press the glue gun's heated tip into the other part of the figurine to melt the surrounding plastic for smoother placement.
      Ask FixBot
    5. How to Fix a Broken Plastic Figurine: step 5, image 1 of 2 How to Fix a Broken Plastic Figurine: step 5, image 2 of 2
      • Align the broken pieces together carefully.
      • Press the two pieces together.
      • Hold together tightly for a minute to bond the pieces.
      Ask FixBot
    6. How to Fix a Broken Plastic Figurine: step 6, image 1 of 3 How to Fix a Broken Plastic Figurine: step 6, image 2 of 3 How to Fix a Broken Plastic Figurine: step 6, image 3 of 3
      • Apply tape to keep the pieces together.
      • Let it sit for 1 hour.
      Ask FixBot
    7. How to Fix a Broken Plastic Figurine: step 7, image 1 of 2 How to Fix a Broken Plastic Figurine: step 7, image 2 of 2
      • Remove the tape top-down.
      • You're finished!
      Ask FixBot
Finish Line
Jackson Smith
157 Reputation
1 Guide authored
UC Davis, Team 2-2, Vidal-Chiesa Fall 2024 Member of UC Davis, Team 2-2, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S2G2
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 42
Past 30 Days: 255
All Time: 1,508
