How to Fix a Broken Necklace
Views: 5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
114
All Time:
5,043
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Do you have an old chain bracelet or necklace that broke, but you still want to keep? Old accessories can always be restored to its original functionality. This guide will provide you with a step-by-step process for fixing broken chains.
    1. How to Fix a Broken Necklace, How to Fix a Broken Necklace: step 1, image 1 of 1
      • Lay your chain necklace on a flat surface.
      • This will keep the chain from tangling.
      Ask FixBot
    2. How to Fix a Broken Necklace: step 2, image 1 of 1
      • Locate the broken link.
      • Place the pliers on the right of the small opening on the chain.
      • Keep your hand a few centimeters lower than the opening of the chain to avoid accidental injuries.
      Ask FixBot
    3. How to Fix a Broken Necklace: step 3, image 1 of 1
      • Pull one side of the link down slightly to make the gap in the chain larger using the pliers.
      • This opens up the chain allowing you to work with it easily.
      Ask FixBot
    4. How to Fix a Broken Necklace: step 4, image 1 of 2 How to Fix a Broken Necklace: step 4, image 2 of 2
      • Repeat step three on the opposite side of the chain.
      Ask FixBot
    5. How to Fix a Broken Necklace: step 5, image 1 of 2 How to Fix a Broken Necklace: step 5, image 2 of 2
      • Take both ends of the chain and hook them together.
      Ask FixBot
    6. How to Fix a Broken Necklace: step 6, image 1 of 2 How to Fix a Broken Necklace: step 6, image 2 of 2
      • Close the chain by using the pliers to push the link to its original position.
      Ask FixBot
    7. How to Fix a Broken Necklace: step 7, image 1 of 1
      • Repeat step six to close the other chain link.
      Ask FixBot
    8. How to Fix a Broken Necklace: step 8, image 1 of 1
      • Your jewelry is ready to be worn!
      Ask FixBot
This creative guide can be used for all accessories whether big or small, wide or thin. Now you can restore old, broken, accessories that still have a special place in your heart.
4 other people completed this guide.
Salonee
263 Reputation
1 Guide authored
Cal Poly, Team 28-4, Green Spring 2015 Member of Cal Poly, Team 28-4, Green Spring 2015
CPSU-GREEN-S15S28G4
6 Members
60 Guides authored
2 Guide Comments
Always great to be able to repair and reuse broken jewelry. A tip on how to add a bright, metal jump ring or chain to an older, more tarnished necklace is to use the flame of a wooden match to burn the newer metal. It will give it an antique look. Try doing it on just one bit of metal to see how it reacts. And, always hold the metal with your pliers, not your hands, when you're burning it. Allow it to cool. Wipe off excess tarnish with a tissue. Note: this needs a wooden match, not a lighter.
Also, to polish sterling chains, you can use a q-tip with fireplace ashes. They work great!
janiceparsons - Reply Share
Fixed a broken chain bracelet with your method!
Thanks a bunch :)
Mihai Patrascu - Reply Share
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 114
All Time: 5,043
