How to Fix a Broken Necklace Chain
Views: 502K
View statistics:
Past 24 Hours:
27
Past 7 Days:
147
Past 30 Days:
676
All Time:
501,549
Comments: 21
4 comments on steps, 17 guide comments.
Go to guide comments
Completed: 38
38 people have marked this guide "completed." Will you be next?
Favorites: 13
13 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Have a broken necklace still lying around because you can't bear to get rid of it? This simple guide to repairing the chain will make it wearable again in no time.
Tools
    1. How to Fix a Broken Necklace Chain, How to Fix a Broken Necklace Chain: step 1, image 1 of 2 How to Fix a Broken Necklace Chain, How to Fix a Broken Necklace Chain: step 1, image 2 of 2
      • Examine the break.
      • If there is an open link in the chain, skip to step three.
      Ask FixBot
    2. How to Fix a Broken Necklace Chain: step 2, image 1 of 3 How to Fix a Broken Necklace Chain: step 2, image 2 of 3 How to Fix a Broken Necklace Chain: step 2, image 3 of 3
      • Use the needle nosed pliers to separate the closure of a link on one side of the break.
      • You do not need this step if your necklace already has an open link.
      Ask FixBot
    3. How to Fix a Broken Necklace Chain: step 3, image 1 of 2 How to Fix a Broken Necklace Chain: step 3, image 2 of 2
      • Hook the closed link opposite the break to the open link.
      Ask FixBot
    4. How to Fix a Broken Necklace Chain: step 4, image 1 of 3 How to Fix a Broken Necklace Chain: step 4, image 2 of 3 How to Fix a Broken Necklace Chain: step 4, image 3 of 3
      • Using the needle nosed pliers, squeeze the ends of the open link together.
      • Make sure the closed link is inside the open link.
      Ask FixBot
    5. How to Fix a Broken Necklace Chain: step 5, image 1 of 1
      • Using the needle nosed pliers, squeeze the closure so that the ends of the link are flush with one another.
      Ask FixBot
    6. How to Fix a Broken Necklace Chain: step 6, image 1 of 2 How to Fix a Broken Necklace Chain: step 6, image 2 of 2
      • Test the closure by gently pulling it from either side. If it comes apart repeat steps 4 and 5.
      Ask FixBot
Now you're ready to flaunt your old necklace once again!
38 other people completed this guide.
Bethany Smith
1,419 Reputation
2 Guides authored
Cal Poly, Team 30-5, Green Spring 2015 Member of Cal Poly, Team 30-5, Green Spring 2015
CPSU-GREEN-S15S30G5
5 Members
72 Guides authored
17 Guide Comments
My chain broke when my 7 year old cousin pulled on it when he was piggy back ridding me. Ha Ha. Only took 20 min to do this. Very easy bit best to have nimble and dexterous fingers
Melvin Ricks - Reply Share
My very new chain had broken a day after my birthday .. and the chain is very special so of course I was panicking trying to figure out how to fix it . I found this website and i fixed it within 10 minutes.
Bethany - Reply Share
With the smaller necklaces, the broken link always falls off really easily, is there a way to make that easier to fix?
Angela Wei - Reply Share
My costly gold chain break down...as it is very lin... How can I joint it
Kunalsam 007 - Reply Share
I would like to say that my gold chain down due to its thinness...how can I joint this chain
Past 24 Hours: 27
Past 7 Days: 147
Past 30 Days: 676
All Time: 501,549
