Introduction
Backpacks are essential for everyday use and travel, but they can wear out over time. A common problem is a broken loop for hanging accessories such as water bottles or key rings, which can be frustrating and limit functionality. We show you how to quickly fix this problem and be ready for your next adventure in no time!
➡️Before you get started, please check the safety disclaimer at the bottom of the page.
Use a seam ripper and a pair of scissors to completely remove the loop and get rid of any loose thread.
Tip: Once you have removed the loop, make sure you leave a space in the seam area to reinsert it later.
Once you have removed the broken loop, stitch both ends together using a sewing machine.
Introduce the stitched loop into the seam hole and hold it together with both hands.
Following the last step, keep holding together the loop with both hands and gently place it on the sewing machine and start stitching.
Use a pair of scissors to clean the area and cut any loose threads.
🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
- Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
- Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
- Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
