How to Fix a Broken High Heel
  1. How to Fix a Broken High Heel, How to Fix a Broken High Heel: step 1, image 1 of 2 How to Fix a Broken High Heel, How to Fix a Broken High Heel: step 1, image 2 of 2
    • Peel back the sole of the heel.
    • This first step is if your heel has not completely broken off yet.
    • If it has broken off cleanly, proceed to Step 5.
    Ask FixBot
  2. How to Fix a Broken High Heel: step 2, image 1 of 2 How to Fix a Broken High Heel: step 2, image 2 of 2
    • Remove the largest 10 x 1/2-inch stainless screw in the middle of the heel with a screwdriver.
    Ask FixBot
  3. How to Fix a Broken High Heel: step 3, image 1 of 1
    • Once the heel is broken off, use pliers to remove the four smaller 30 mm long, dia. 1.5 mm nails on the heel.
    • It’s alright if they bend and break. That is why we recommend buying extra nails.
    Ask FixBot
  4. How to Fix a Broken High Heel: step 4, image 1 of 1
    • Sand the heel down after removal of all the nails.
    • This will make the surface smoother for reattachment.
    Ask FixBot
  5. How to Fix a Broken High Heel: step 5, image 1 of 1
    • Align the heel back in place.
    • Use a hammer to reinsert the four smaller 30 mm long, dia. 1.5 mm nails.
    Ask FixBot
  6. How to Fix a Broken High Heel: step 6, image 1 of 1
    • Use a screwdriver to reinsert the largest middle 10 x 1/2" stainless steel screw into the heel.
    Ask FixBot
  7. How to Fix a Broken High Heel: step 7, image 1 of 2 How to Fix a Broken High Heel: step 7, image 2 of 2
    • Now that the nails are all in place and the heel is secure, use leather repair glue to glue back the sole.
    Ask FixBot
  8. How to Fix a Broken High Heel: step 8, image 1 of 2 How to Fix a Broken High Heel: step 8, image 2 of 2
    • Find any heavy object in your home, and lay it on top of the sole to make sure the glue settles.
    Ask FixBot
That concludes our guide we hope you have found this helpful.
Cindy Tan
157 Reputation
1 Guide authored
UC Davis, Team 1-2, Andersen Winter 2023 Member of UC Davis, Team 1-2, Andersen Winter 2023
UCD-ANDERSEN-W23S1G2
2 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 100
All Time: 2,100
