How to Fix a Broken Decorative Ceramic Bowl
    1. How to Fix a Broken Decorative Ceramic Bowl, How to Fix a Broken Decorative Ceramic Bowl: step 1, image 1 of 1
      • Clean the broken ceramic with rubbing alcohol.
      Ask FixBot
    2. How to Fix a Broken Decorative Ceramic Bowl: step 2, image 1 of 2 How to Fix a Broken Decorative Ceramic Bowl: step 2, image 2 of 2
      • Mix epoxy to paste the pieces of ceramics together.
      • If you are using Epoxy that is not pre-mixed, combine the two-part Epoxy using a paper pad and wooden stick.
      Ask FixBot
    3. How to Fix a Broken Decorative Ceramic Bowl: step 3, image 1 of 1
      • Apply Epoxy to the edges and place the broken ceramic pieces in their permanent location.
      • Press the broken pieces firmly together.
      • Epoxy will ooze out. Do not wipe off to avoid smearing.
      • Use the container of sand to help hold pieces in place.
      Ask FixBot
    4. How to Fix a Broken Decorative Ceramic Bowl: step 4, image 1 of 2 How to Fix a Broken Decorative Ceramic Bowl: step 4, image 2 of 2
      • Use clay for securing the attached pieces during the curing process.
      Ask FixBot
    5. How to Fix a Broken Decorative Ceramic Bowl: step 5, image 1 of 1
      • Use the Exacto knife to remove the excess dried Epoxy from the bowl.
      • Be cautious while handling the tool. The blade is very sharp.
      Ask FixBot
    6. How to Fix a Broken Decorative Ceramic Bowl: step 6, image 1 of 2 How to Fix a Broken Decorative Ceramic Bowl: step 6, image 2 of 2
      • Check if the pieces are secure.
      • Let the bowl set for an hour before use.
      Ask FixBot
Finish Line
Katelynn
133 Reputation
1 Guide authored
UC Davis, Team 4-3, Vidal-Chiesa Fall 2024 Member of UC Davis, Team 4-3, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S4G3
3 Members
12 Guides authored
1 Guide Comment
This is a helpful and easy-to-follow guide. I like that it focuses on repairing a decorative ceramic bowl instead of immediately replacing it, which is both cost-effective and environmentally friendly.
Pick low - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 101
All Time: 751
