How to Fix a Broken Ceramic Vase
    1. How to Fix a Broken Ceramic Vase, How to Fix a Broken Ceramic Vase: step 1, image 1 of 1
      • Examine the damage to the vase. Determine how large the cracks and chips are.
      • Smaller cracks can be fixed with a ceramic adhesive, while larger cracks may require putty.
      Ask FixBot
    2. How to Fix a Broken Ceramic Vase: step 2, image 1 of 1
      • Sand the broken edges and cracked pieces on the vase with a sander block.
      Ask FixBot
    3. How to Fix a Broken Ceramic Vase: step 3, image 1 of 2 How to Fix a Broken Ceramic Vase: step 3, image 2 of 2
      • Apply ceramic adhesive to the broken pieces and press them together for two minutes.
      Ask FixBot
    4. How to Fix a Broken Ceramic Vase: step 4, image 1 of 1
      • Secure masking tape over the cracks and let the vase dry for 3 hours.
      Ask FixBot
    5. How to Fix a Broken Ceramic Vase: step 5, image 1 of 1
      • After the vase dries, clean the areas with a cloth where chunks of ceramic are missing.
      Ask FixBot
    6. How to Fix a Broken Ceramic Vase: step 6, image 1 of 2 How to Fix a Broken Ceramic Vase: step 6, image 2 of 2
      • Use a chisel scraper to fill in the missing areas with putty and allow it to dry completely.
      Ask FixBot
    7. How to Fix a Broken Ceramic Vase: step 7, image 1 of 1
      • Select a paint that matches the vase and use a soft paintbrush to paint the dry putty wall.
      Ask FixBot
    8. How to Fix a Broken Ceramic Vase: step 8, image 1 of 1
      • Let the paint dry for one hour on the vase and your repair is finished.
      Ask FixBot
Finish Line
1 Guide Comment
What kind of putty do you use?
Jill Martin Ward - Reply Share
Past 24 Hours: 13
Past 7 Days: 63
Past 30 Days: 252
All Time: 6,630
