How to Fix Xbox 360 Controller Joystick Drift
    1. How to Fix Xbox 360 Controller Joystick Drift, How to Fix Stick Drift on Xbox 360 Controller: step 1, image 1 of 2 How to Fix Xbox 360 Controller Joystick Drift, How to Fix Stick Drift on Xbox 360 Controller: step 1, image 2 of 2
      • Remove seven screws from the back of the controller using a T8 Torx screwdriver.
      Ask FixBot
    2. How to Fix Xbox 360 Controller Joystick Drift: step 2, image 1 of 2 How to Fix Xbox 360 Controller Joystick Drift: step 2, image 2 of 2
      • Remove the back to see the motherboard.
      • Do this with caution as it could easily be damaged if wires disconnect.
      Ask FixBot
    3. How to Fix Xbox 360 Controller Joystick Drift: step 3, image 1 of 2 How to Fix Xbox 360 Controller Joystick Drift: step 3, image 2 of 2
      • Gently dab a cotton swab with isopropyl or rubbing alcohol to the joystick in a circular motion.
      • Be careful when adding liquid; too much liquid can damage the controller.
      Ask FixBot
    4. How to Fix Xbox 360 Controller Joystick Drift: step 4, image 1 of 2 How to Fix Xbox 360 Controller Joystick Drift: step 4, image 2 of 2
      • Use a blow dryer to dry both the left and right joysticks.
      Ask FixBot
15 other people completed this guide.
Luis Ramirez
435 Reputation
1 Guide authored
6 Guide Comments
This is not a genuine Xbox 360 controller and you truly aren't doing anything at all. You haven't even removed the thumbsticks to service the internals of the sensor assembly lol.
Alexander Dimitrov - Reply Share
Hi, I did this with a genuine controller and it completely worked for me. I just wiped the metal frames and went round the inside-joystick that I could, with the Q-tip.
ShadowNinja5764 - Reply Share
is replacing a joystick on a Xbox 360 wireless controller the same as replacing a joystick on a PowerA wired controller
batman2345 - Reply Share
Not sure, but i do know you need to be careful. The circuit board in the Xbox controller is very easy to damage. The pads can lift easily if not careful when desoldering. Add solder before you try to desolder.
Burned - Reply Share
I believe this is a fix only for if you get premature stick drift. Stick drift from prolonged/intense use requires replacement of parts.
Wes Plants - Reply Share
Past 24 Hours: 28
Past 7 Days: 200
Past 30 Days: 801
All Time: 50,164
