Up to 20% off select tools
How to Fix Subwoofer Amplifiers
Views: 3.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
35
Past 30 Days:
194
All Time:
3,300
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 25 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This is how you get better connection for your amplifier, which can be the cause of it not working. The main issues that happen when your subwoofers are not working includes improper wire connection, blown fuse, or shortage in wiring.
    1. How to Fix Subwoofer Amplifiers, How to Fix Subwoofer Amplifiers: step 1, image 1 of 1
      • Disconnect the black (negative) cable from the battery to disable the electrical connection.
      • Always disconnect the negative cable before the positive cable.
      • Disconnect the red (positive) cable from the battery to disable the electrical connection.
      Ask FixBot
    2. How to Fix Subwoofer Amplifiers: step 2, image 1 of 1
      • Pull the fuses out and make sure that they were not blown.
      Ask FixBot
    3. How to Fix Subwoofer Amplifiers: step 3, image 1 of 1
      • Undo and remove all wires from the amplifier.
      • This should include the battery wire, ground wire, speaker wires, remote wire from the radio, and sound wires that also come from radio.
      • Remove and check the fuse from the amp to make sure it is not a blown fuse.
      Ask FixBot
    4. How to Fix Subwoofer Amplifiers: step 4, image 1 of 1
      • Strip the wires so they can have a better connection.
      • Twist the exposed copper wiring to make it easier to connect to the amplifier.
      Ask FixBot
    5. How to Fix Subwoofer Amplifiers: step 5, image 1 of 1
      • Replace the wires in their designated slots.
      • Tighten the clamps all the way down.
      • Wiggle and tug on the wires to make sure they are secured nice and tight.
      Ask FixBot
    6. How to Fix Subwoofer Amplifiers: step 6, image 1 of 1
      • Replace the battery wires.
      • The red wire should go to the positive side, and the black wire should go to the negative side.
      Ask FixBot
Finish Line
Author
with
Luke Turner
154 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 194
All Time: 3,300
